Interior colored vent clips
Wardawg
2017 GT350, 2013 Escape, 2006 Explorer
I've been designing a model to replace the interior vent clips and I think I have a pretty solid solution and would appreciate your thoughts.
I don't plan on painting them, and have them printed in a high enough quality that it isn't noticeable.
Ford Bronco Interior colored vent clips 20220323_140454
Ford Bronco Interior colored vent clips 20220323_140731
Ford Bronco Interior colored vent clips 20220323_140740
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
I wouldn’t mind seeing a little more recess in the front strip, make it deeper. Also, is it possible to add some radius to the edges to soften the look a little bit?
Wardawg
Made the recess a little deeper. The corners are modeled rounded, just not printing out like that. Got a new smaller nozzle on the way, might work out better.
Ford Bronco Interior colored vent clips 20220330_201908
Ford Bronco Interior colored vent clips 20220330_201842
Ford Bronco Interior colored vent clips 20220330_201917
Ghiaguy0
Don
Ohio
2021 f150 Powerboost
can you make me a set of the blue?
deon918
Deon
Escape
Any update on these ?
Wardawg
Unfortunately I had discovered the material I used would warp when the heaters were used on high. I wouldn't have thought the temp got over 160 degrees! So I went back to the drawing board, modified my design, and I'm now using a different material.
They are now printed using ASA, which is UV resistant and has a much higher temperature resistance. I've had them installed for a few months now and have tested them in the hot California sun with the heat on full blast with no issues.
I currently have them only in black, but if interest picks up again I can look into using other colors. Please check out Ebay and Etsy if you're interested in picking some up
Ford Bronco Interior colored vent clips 20220824_192231
Ford Bronco Interior colored vent clips 20220824_192319
Ford Bronco Interior colored vent clips 20220824_192343
Ford Bronco Interior colored vent clips 20220824_192354
