Interior Bike Rack
reidski29
Reid
Grand Rapids, MI
2013 Ford Expedition, 2018 Santa Cruz Blur
This is a really clean solution! Quick search showed bed rail and rooftop fork mounts.. I'm assuming the bed one would mount better to the 2x8? Does it matter? Thanks for the pro tip!
This is similar to what I am saying. Just get the fork mount that bolts and mount it to the wood.
Ford Bronco Interior Bike Rack 1619625721487
Ford Bronco Interior Bike Rack 1619625744843
MostHumblest
MostHumblest
NY
That's what I was imagining but not what I had found originally. Rock on, this is a great idea. Thanks!
reidski29
Reid
Grand Rapids, MI
It works much better than lying your bike down as it holds it firm and upright. Worse case a bungee cord over the frame, or the seatpost to a point in the vehicle works for stabilization if needed.
Considering I ride over 100+ per year, and have a bike in my vehicle 200+ times a year this is my preferred way for transport. I don't even think I would get the optional fork mount from Ford as A)this method is cheaper and B) likely that only fits 100 mm front forks (mine range from 100, 110 thru axle, 150 thru axle and I needed different set ups for different bikes).
Likely if you don't know you just have a simple fork mount 100mm width and it will work fine.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Roof mounts beware. By the time you put the rack on, that's a pretty high lift for the bike. Then there is always this...
Ford Bronco Interior Bike Rack 1619635404967
A friend of mine forgot his mountain bike and turned on a road with an immediate low railway underpass. Shattered the glass roof of his van and messed up the bike...plus they are still out in the weather, if you have good bikes you want to protect.
reidski29
Reid
Grand Rapids, MI
Yes roof racks, versus inside versus hitch mount is always a question. I go inside first, then hitch, last roof.
I personally am not looking forward to the swing tailgate, as I hope it clears my hitch mount. Worse case I just get a drop hitch and call it good (for all those times I have camping equipment inside the vehicle and my bike(s) on the hitch).
When I do use the roof rack, I put a cone down in my garage space indicating that I should not drive in! Helps block it mentally.
Geronco
Wauwatosa, WI
Suzuki SV650
I just bolted some fork mounts into the back side of the roll bar…of course this was in 1994 on a 76 Bronco…
Meandeane
Aaron
Austin, TX
2021 4 Door Ford Bronco Badlands Sasquatch
Tried to get my MTB in the back for the first time and there's not as much clearance as my Jeep had since the seats don't lay all the way flat. Maybe others will have more luck but even with the dropper post all the way down I couldn't get it.
SnowBronco
Canada
My 29" Evil Following and my wife's trek made it in No problem in the soft top. Along with a ton of other shit. Hard top will have even more clearance. Just drop the seat post. I'm going to be making a fork mount for the back of mine shortly when I get my hard top.
stachequatch
Jason
VA
'22 Bronco
I have a 3-bike hitch rack on order. While I wait for it to come in, I've been running this set-up and it's been working great. It's just two Husky velcro straps from the anchor points to around the fork and another strap (old carseat anchor) from between the molle panels on the front seats and through rear wheel.
I plan on getting a getting a fork mount to make this setup more secure. I also want to see if I can shuttle four bikes (three on the hitch rack, one in the truck) and still seat two people in the back seat.
Ford Bronco Interior Bike Rack IMG_0089
Ford Bronco Interior Bike Rack IMG_0090
Mortonm
Canada
2022 Ford Bronco Black Diamond
This is my setup. New Bronco old school steel.
It's a factory rack from an xterra. It works really well. These old bikes aren't as long but plenty of room
Ford Bronco Interior Bike Rack 20221102_123216
Black_Stallion13
Cincinnati
Tacoma
Here's mine - I cut an extra bed rail from my old Tacoma to fit the Bronco cargo width. With a ratchet strap across the d-rings, the whole thing is solid. The beauty of the Tacoma rail is it uses t slot bolts and accessories so you can quickly slide and tighten everything where you want it. The fit is a little snug with a full size 29" mountain bike but I do have the added floor height of the slide-out tailgate.
Ford Bronco Interior Bike Rack PXL_20221231_055419082
CAbronco23
2023 Bronco
I'm curious how this setup worked out for you. I'm looking for a solution to keep my mountain bike upright inside the bronco. Is the bike stable? It looks like it would just fall over. Have you tried anything else? Thanks.
