Instrument Cluster Black when Cold Outside
f18f_guy
Paul
DC
Ford Bronco
Good morning!
Over the past few weeks my dash instrument cluster is black when the temp is below around 55 degrees. After I drive it a bit (20+ minutes) with the heat on, I can park and re-crank and get it back. All functions associated with the dash display, e.g., cruise control, etc., work. Sync works fine.
Additionally, both front and rear cameras are intermittently functional -- I can find no corollary and/or ambient conditions, like temperature, associated with the cameras. Drives me crazy.
My questions: Has anyone experienced the IC going dead due to outside temperature, and if so, was it rectified (and how)? Secondly, is it possible the cameras intermittent functionality is associated with the IC, like a wiring harness, etc.?
Thank you, All!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning!
Thank you, All!
Hi Paul! I can look into your Bronco's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
Good morning!
Thank you, All!
No issues with mine and our temp runs between 20 and 30 deg in the morning. Sounds like an electrical problem. Keep us posted...
garyobx
gary
Kittyhawk NC
2010 jeep
mine is doing the exact thing. after i drive it awhile and shut it off it comes back on. what did you find out? thanks,, mine is a 2021
