Installing air horn?
Bubba Bronco
Chuck
Connecticut
Bronco 4 dr badlands
Does anyone have any recommendations on how to put a air horn into a four-door Badlands?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Yeah, I think if you roll down your window and do this outside the vehicle, it works pretty good. It may only work on the Outer Banks trim though… sorry.
Ford Bronco Installing air horn? 1641082823950
Sigma1180
Dan
Jersey
03 Mitsubishi Lancer
Hey did you ever figure it out? Just got one and was just going to wire it straight to the factory aux switches
Johnny Mo
Westchester County, NY
teachu2shoot.com
I don't have my Bronco yet, but my plan is to use one of the aux switches and a relay to have the switch turned off = air horn, turned on reverts to factory horn...reason for that is in the event there is any issue with the air horn, air lines, compressor etc, just go back to stock without having to re-wire.
Secondly, will likely use an ARB single compressor mounted in the under rear floor storage, mount a tank to a frame rail, with a pressure switch and a remote filler valve to hookup an air up/down hose set or any other air tool/ratchet. Horns will likely get mounted somewhere behind the grill or bumper (Hadley Big Bully) twin horns about 15" long. Will keep the electronic release valve pretty close to the horns so that there isn't much of a delay, and probably uses stainless braided lines or possibly even hard pipe (brake lines I'm thinking) custom bent.
But I haven't given it too much thought. ;)
