Installed: Fabtech 1.5" front strut spacer level kit, 2dr OB Squatch!
Happy
Jerry
Missouri
CJ5, Wagoneer
It ain't ugly!
Laminar
Iowa
Cougar
Is this a wheel spacer or a level kit?
RDeFran
Rich
Knoxville, TN
Many...
We did a non squatch BL last week, 1.5" Fabtech front, 1/2" of Rough Country spacers in the rear. The Rough Country comes with Four 1/4" Shims for the top, two 1/2" for the bottom front (because of leverage 1/4" spacer = 3/8" to 7/16" of front lift). The top shims work on the back to give 1/4" of extra height to prevent the Alabama Rake. To level a non Squatch BL, the Rough Country minus one upper shim should do it.
Ford Bronco Installed: Fabtech 1.5" front strut spacer level kit, 2dr OB Squatch! 20211220_115349
Ford Bronco Installed: Fabtech 1.5" front strut spacer level kit, 2dr OB Squatch! 20211201_133820
Ford Bronco Installed: Fabtech 1.5" front strut spacer level kit, 2dr OB Squatch! 20211201_133829
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
Looks good with no additional payload. Add weight in the rear and it will look different.
RDeFran
Rich
Knoxville, TN
Many...
The Rough Country spacers work perfectly for a minor adjustment if you need a little rake, five minute install. It squatted way down when I hauled a load of firewood the day I bought it - and that was bone stock - and on the way home from picking it up.
Ford Bronco Installed: Fabtech 1.5" front strut spacer level kit, 2dr OB Squatch! 20211218_095715
Joec410
Somerset PA
2017 F-250 Superduty, 2017 Shelby GT350
What size wheels are those? 20x9? that look great!
RDeFran
Rich
Knoxville, TN
Many...
Those were TIS 20x9 ET19 with 35x12.50/20 Toyo Open Country on a customer's BL.
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
So you ordered a Fab tech level kit and put it fully on in the front, then ordered a rough country level kit and installed only half of it in the back, so you lifted slightly, and also only slightly changed the rake? The rear bolts were long enough for this ? This is exactly what i wanted to do, is there any worries of wheel going to far up OR down? I dont know too much but i wanted some lifet not just only level, wasnt actually big on the idea of "level" since ford doesnt do it that way from the factory, if this is only leveled slightly that seems perfect?
Erick2123
Erick
Lincoln
21 Acura TLX
Measurements are dead level after install.
looks awesome i ordered the same kit was wondering what it actually looked like on a stock badlands set up. appreciate it!
RDeFran
Rich
Knoxville, TN
Many...
There is plenty of bolt on the rear for the Rough Country. And yes, Fabtech front, RC rear.
RDeFran
Rich
Knoxville, TN
Many...
You will want the RC rear to level up a BL non Squatch - of just a RC kit up front to match the stock rear.
Erick2123
Erick
Lincoln
21 Acura TLX
oh dang i thought the install was done on an actual Sas, have you guys installed the Fab only on a 1.5 on an actual SAS?
RDeFran
Rich
Knoxville, TN
Many...
The above two door is a SAS. It took the Fabtech 1.5" and I am putting one 1/4" RC in the rear just in case I have a cooler back there.
