Installed ARB Rear Differential Cover
Mn22bronco
Richard
Minnesota
instagram.com
Bronco 2022 Big Bend, 2018 Expedition-,
Upgraded Rear Differential.
Installed the ARB rear differential cover on my 2.3L Big Bend. It was 100% cosmetic for me due to doing a Red White and Blue color combo.
Ford Bronco Installed ARB Rear Differential Cover 325691A8-A907-41DE-B5B6-368FC0966B01
Ford Bronco Installed ARB Rear Differential Cover D38F53E8-0E29-40BE-B97C-DDC7E77F3F50
hotrodtim
TIM
23 F-150-RCSB 22 WILDTRAK 19 EXPED. 68 BRONCO
tsielski
Tim
Sunshine state
2022 Ford Bronco, 2020 Range Rover Velar SV R
I second that question, as the ARB cover looks like it might slightly reduce the gear oil capacity over the stock cover, but looks are deceiving. Ford Performance offers a nice nodular iron cover for the M220 on the Ranger, which 'might' work on the Bronco (will fit the M220 on the Bronco, only potential issue is sway bar clearance). The ARB unit is nice in that it has a drain plug. The Ford performance unit for the Ranger does NOT have a drain plug. A little nit is the M220 on the Ranger has a drain plug on the front passenger side of the housing. The M220 on the Bronco has a flat pad there, but no drain plug. No idea why not.
Mn22bronco
Mn22bronco
Richard
Minnesota
instagram.com
My Mechanic used the recommended Oil amount directly from Ford. The only difference is you have a dip stick you need to use needs to be marked that amount on the cover itself.
F OR D
BD Green Machine
looks great, i have a strange attraction to aftermarket rear diff covers. noted for when it is time to service ;)
Fmuguira
Frank
Idaho
Jeep TJ
My ARB covers on a Dana 44 and Dana 30 also have a strong magnet built into drain plug. It pulls out some metallic sludge every time you can fluid !!
Fmuguira
Frank
Idaho
Jeep TJ
Change fluid
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
What did you use for the bolts with studs that the brake line clips into? Since the holes are recessed you can’t reuse the same bolts.
redone17
Cold Spring, NY
Also, did you use the 25.4 ft-lb spec from the ARB install instructions or the 177 in-lb from the service manual?
Deleted User 5719102
Who's
On a Lake
22 2dr
I installed an ARB cover and made my own brackets to secure the brake line.
Ford Bronco Installed ARB Rear Differential Cover IMG_20230227_170105
Ford Bronco Installed ARB Rear Differential Cover IMG_20230204_123207
Ford Bronco Installed ARB Rear Differential Cover IMG_20230204_124903
Ford Bronco Installed ARB Rear Differential Cover IMG_20230204_131925
Ford Bronco Installed ARB Rear Differential Cover IMG_20230204_131943
redone17
Cold Spring, NY
@Grumpy - solid idea.
I worked around it. I used 4 washers on the stock stud bolts so that I had enough of the 13mm nut to bite. I moved the clips up to the same bolts as you. Not the best, but didn’t expect this bump in the road.
Ford Bronco Installed ARB Rear Differential Cover IMG_4047
Ford Bronco Installed ARB Rear Differential Cover IMG_4048
redone17
Cold Spring, NY
Also, I went with the ARB suggested 25 ft lbs since it was hardware specific. Stayed with the two 17 ft lbs on the stud bolts.
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
Here's mine!
Ford Bronco Installed ARB Rear Differential Cover AE42FD07-2365-4C28-94B3-713E4DEC4C8E
nd4spd569
Thomas
2021 Bronco Badlands Sasquatch
Used this idea this weekend. Changed at 40k miles. Was definitely dark and lots of metallic sludge on the oem magnet. Hopefully just part of breakin.
I used 4 of the 3/8” rubber clamps. One I straightened and removed the rubber and then attached the second clamp on reversed inward. The length was perfect.
https://www.homedepot.com/p/Gardner-Bender-3-8-in-Rubber-Insulated-Clamp-2-Pack-PPR-1500/202906415
Ford Bronco Installed ARB Rear Differential Cover IMG_9225
