Installed Alignment Cam Lockouts
vrtical
Doug AI
GSMNP, TN
Fords
Got this project done today. These are by BDS Suspension. Bronco is headed to a 4x4 alignment rack on Wednesday. Now I won't have to worry about the alignment moving around which happens when you off road enough in the rocks and/or jump it.
Ford Bronco Installed Alignment Cam Lockouts 1000003196
Ford Bronco Installed Alignment Cam Lockouts 1000003198
swamp2
So there is a weld and no weld solution for this? You have to have adjustable UCAs also, right?
Charlesbrown165
Chuck
Johnstown, NY
2012 Jeep Wrangler Rubicon 2 Dr Cosmo Blue
link to order?
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Not sure what your asking. I am using the stock LCA's and the OEM pins.
swamp2
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Alignment was done yesterday and now it's back to OEM spec parameters plus my steering wheel is straight now.
Ford Bronco Installed Alignment Cam Lockouts 1000003211
