Ineos grenadier
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
My son's Grenadier is just waiting on final stuff. His order was in the first 100.
There is a minor issue with software for the trailer hitch so they won't install those yet until remedied but granted a discount now and free install of pieces when available.
I will post my impressions after he takes delivery, which should be well before Christmas.
They also announced that they will be taking orders for the Quartermaster Q1 2024. It unfortunately may be subject to the fricken chicken tax on light duty pickups unless it can get labeled as heavy duty? Or toss in a pair of seats in the bed can y'all say BRAT?
His one comment from test driving was that it drives like a truck and the front axle does not self center after a turn which may just be a caster issue
The turning issue is real and its not a caster issue, its because it uses recirculating ball instead of rack and pinion. Some say they got used to it on the test drive. I did not, and I can see my wife or myself having an accident in tight Dallas driving. I was not happy with it or a few other small but irritating issues. Other than that, it is built like a tank (or more like a tractor). Extremely sturdy. I'm on the fence about mine.
harpo
not as many as I thought
I took a few photos of a Grenadier at SEMA - one thing I found interesting is the L-track built into the sides (it comes that way from the factory). I'm not sure what it'll be used for but I'm anxious to see the uses people come up with when enough Grenadiers get out into the field. Any ideas? It wouldn't be hard to add L-track to the sides of a Bronco if there was a good use for it.
Definitely like the center stack and overhead panel...
Thanks for the pictures!
I had a half second of "WTF is a "window dem-ist" " before I bought a clue.... De-mist ; )
uncledoodoo
Everglades
Everglades
Because people are used to letting the car self re-enter and this one won't. I'm not questioning their reliability or ruggedness. I just don't like it anymore. It wouldn't be bad if it didn't take like 4 full turns of the wheel to go from lock to lock. The ratio is pretty ridiculous.
zuke
Stafford VA
Lots of vehicles use recirculating balls (Steering Box) setups and still return to center on their own. If that weren't the case, we'd have Wrangler's and 1 ton pickups slammed into light poles and tree's all over the world.
Proper Toe is required to self center steering, regardless of the system used. Proper caster also has a big effect on self centering and tracking, and lifting a solid axle vehicle will often change the caster if arms aren't adjusted to maintain the factory caster.
Without knowing the factory alignment specs on the Grenadier, I can't say if the failure to return to center is a problem or a feature though ;)
mackoy21
Marco
San diego
bmw e36
they are opening a ineos mini dealership right in front on my work, im going to test it out too.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I'm thinking that particular car isn't correctly aligned. Lot's of the demos have been used for press events an have been well off roaded. The two IG at my local dealership have mud stuck in the tires and under-body.
I have heard that the steering is very slow but can't believe that they would build something that doesn't self center. That is going to be lawsuit central.
uncledoodoo
Everglades
Everglades
The failure to return to center is well documented in the IG communities. The dealer even explained it (warned about it) when taking it out to test drive. The piss-poor steering ratio compounds it. The whole idea is that bumping over rocks and ruts doesn't jerk the wheel, so I'm sure its impressive off road.
67BroncoG1
Ron
CA
If that's the case then people are going to crash these on road at high rates. Wait until the insurance companies adjust their premiums to reflect the actual loses.
MtnRanger
Usa
Gladiator
On the highway you don’t even notice it. It has a bunch of issues, but steering isn’t one.
Reverse camera is quite terrible.
Dealer network is sparse.
Price is too high.
But the drive itself and quality of suspension, engine, and transmission are all amazing.
On the other hand, this seat lever is minor but it bothered me, it sticks out like 3 inches poking the back of the leg when trying to rest it
Ford Bronco Ineos grenadier IMG_0297
uncledoodoo
Everglades
Everglades
Price is too high.
Its definitely an issue unless you drive only on the highway. To each his own situation I guess, but it was the most annoying thing on my test drive in the city with constant slow traffic and turns into congestion having to whip the wheel back around over a full turn each time. Mine is due in Q1 of 24, I will definitely have to drive it again before deciding. On the other hand there were many things I liked a lot, including the standard interior as opposed to the leather (I drove one of each). I also loved the heavy/solid doors, the forward visibility, the switches and overhead console. I thought the power adequate, but closer to that of a jeep n/a 6cyl than the Bronco. In fact when I returned from the test drive and got back into my F150 Lariat 3.5 EB, I realized how much I really love my Ford. If I don't have a build date on my Ranger Raptor or my HE Bronco by the time the IG is ready, then I may still end up with it, it is a very unique vehicle and that is the best thing about it in my opinion.
buzpro
Binky
Tacoma
It needs a comparison video done .... A bronco, a jeep a 4-runner and a grenadier all doing the same trail.
AND PLEEEEEEEZ don't pick another bunny trail like the one in this video!
JohnnyBronco
Pennsylania
X4
It'll be just like driving a Bronco 1G
67BroncoG1
Ron
CA
You can make a first gen bronco drive pretty damn good. My ‘67 drives great although noise cancelling ear pods are a help for long trips.
PrepVet
North Central WI
A bunch.
not my video.
JohnnyBronco
Pennsylania
X4
First ride as co-driver (no such thing as a front seat passenger in a Grenadier) in my son's new beast. First impressions to be followed with more detail as his miles roll up
1. short 120 mile trip home from dealer but his screen recorded 17.8 mpg - impressive for first drive
2. steering wheel is a tad off center and will have to be addressed
3. otherwise build quality is top-notch
4. too much vibration through the floorboards on simple gravel roads - whether it is because the BFGoodrich tires need some tread worn off or that the 48 psi spec is too high or that some suspension components are too stiff - it certainly is annoying
5. on highway it rides like - like a 4wd truck from the last century - not that that is bad but it might be tiring for a 2100 mile cross-country trip
6. no arm rest on door, at least in co-drive seat
7. footroom is compromised a bit by transmission bulge
8. with no footsteps, only rock rails (as ordered) it is a much higher access and egress than my Bronco for which I do not even use my side steps (32" tires)
9. steering , yes , is slower than a rack & pinion but will self-center somewhat as you drive. An r&p recovers faster but this should not be the cause of any accidents - long time ago a mentor told me most steering related accidents were caused by the loose nut behind the wheel.
10. 5 yr 60k warranty - which they have to be better than the field being new to the party
11. regular bank financing is better than what they offer in-house
