Maharba
Matthias
2023 Bronco
The joys of waiting for vehicles: Maybe most of the kinks will be worked out by the time I get mine. Friend was telling me, "Don't get the Bronco! It's trash! I've seen so many complaints about it!" Alas, here I am, undeterred and patiently waiting. Still may have to get aftermarket Tie Rods. Wonder if they fixed the issue with the front drive shaft that somebody created an aftermarket bushing for.
John94
Detroit
4dr Black Diamond Sas
PICTURE AND VIDEO ATTACHED OF THE ISSUE.
HELL YES.
I’ve been reporting highway vibrations that dissipate in 4x4
Everyone keeps telling me it’s my wheels which have been balanced three times. Dealer said it’s normal. Just read this and checked my boot. ITS RIPPED OPEN
UPDATE: Mine is an august 2021 build BUT the boot IS cracked
DONT LET THE BUILD DATE DETER YOU. CHECK YOUR STUFF
Ford Bronco INCOMING: Driveshaft Recall (Customer Satisfaction Program 22B27) - replacement needed to avoid cracked boot 9421B1C8-DFC1-40B8-850E-C2EBEADDB502
JohnnyBronco
Pennsylania
X4
HELL YES.
Well the letter says they will replace the shaft, not the boot. And my build date is within range but no letter yet...and no notice in the Ford Pass app
John94
Detroit
Boot is the problem - it’s part of the shaft. Both will certainly be replaced
BroncoB
Christine
Tampa Fl
Bronco First Edition
Good thing they acknowledged this so you folks don't have to try to convince your dealer there is a problem. My dealer could not replicate it a few times until they finally had me in the shop to point it out. You may not know you have this problem if you don't take your top off, that is the only time I could hear it. Has to be warm, like 20-30minutes of driving. Jack up one front tire and spin, you'll hear the driveshaft making funny noises.
Sethtsmith
Seth
2012 F-150 FX2 Supercab
Humm. So my bronco that was built the week of 8/8 AND IS STILL NOT HERE already has a recall.. got it.
dfresh73
Doug
Kentucky
Range Rover
UPDATE: This affects all Broncos with build dates from 9/23/2020 through 9/17/2021.
I have the same questions. I will update this thread as more info comes in.
build date 9/23/2020? Couldn't even order until early 2021.
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
I reported this months ago, had it on the list for when they did my warranty MIC top replacement. Explained to the service writer exactly where it was, how I identified it, and that it only does it hot. Pick up the Bronco 4 days later, he says they didn't mess with it because they didn't have any parts and he didn't want to damage the boot without a replacement on hand, going to order parts.
Time goes by, no word. I call, they tell me they couldn't replicate it when they had it. No shit, has to be hot. They tell me to bring it in, I said I'm not leaving it with you until you have parts. I'll bring it, you can check it out hot and order what you need.
I show up explain why I'm there...."so you're dropping it off?" NO someone needs to check it now. He gets the service manager who comes out, gives it a listen, says we'll check it out. Sure enough, exactly what I said it was.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Buck₩ild
Buck
Canada
Wrangler Willys, Bronco BD, Cherokee
Thank god 2022 are not affected.
Already had windshield recall
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
FleshTuxedo
A
PA
'22 OBX 2dr.
Where on the FordPass app would you see recalls?
