Icon Rebound Beadlock Wheels
BAUS67
redneck
Central PA
Clever. I've never had an issue with the tire spinning on the wheel, just losing beads. This would work well for my use.
on the spinning issue ..............
Back in the 90's I was drag racing a fox body and was contemplating using wheel screws because the other racers had them and they would always say "You need to screw them tires down"
So for a test I put a shoe polish line on the wheel and the tire. after a day of racing the tire had moved about a half an inch. So does it happen ?? Yes. Is it a lot?? No. Now if you would have a 1500 HP car without a doubt they would spin more. But for low power I would say the spinning is minimal. 😁
broncoepic
Bronco Badlands Sasquatch
I've purchased these wheels and expect to have them delivered next week and will be mounting a set of Mickey Thompson Baja MTZ P3 35" MT tires. These wheels being DOT compliant while providing similar capabilities as a traditional bead lock wheel w/o the associated risks were a key factor in my selection process. I currently run the Method Trail Series w/ Bead Grip Tech wheels on my current rig for similar reasons.
VelocityBrew
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
At 2lbs over the non-beadlock Rebounds it isn't that much of a weight increase either. I am considering them.
broncoepic
The relatively low weight of the wheels was an unexpected bonus. Icon's video does indicate that they added additional material to improve strength. I'll post plenty of pics and info when I get them and mounted up with tires. One of my challenges at the moment is figuring out the compatible TPMS sensor. Ford's catalog appears to have two different parts listed, a 315MHz and a 433MHz version.
Silver-Bolt
Bill
Eureka, MT
Do the screws have an o-ring? How do the seal?
broncoepic
Alex Mcknz
Alexander
1989 Ford Bronco
The concept appears to be far superior, accomplishing the same levels of traditional bead-lock wheels. I'm kind of curious.
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
I have seen wheels spin inside the tire when wheeling with very low air pressure. Much depends on the tire, some tires are just harder to unseat and grip the wheel better. Mud and rock grit can get into the bead, between the rim and tire and cause small leaks, which is much harder to do with a beadlock. Still, this is a pretty cool idea and would work well in most situations. I'd want to carry a bag of spare O rings for the bolts, just in case. I could go down the DOT rabbit hole, but....... :giggle:
