IAG V2 Steps
BroncoAZ
Mitch
I like the look of those but do they fit rock rails? Doesn't look like it. And with the B6G discount on AR's billet aluminum steps I think I'll be going that route.
Nope, the rock rails have to be removed for the Greenlane ones to be installed.
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
For those that have been taking these on and off, are they damaging the OEM rock rails at all?
PVB90
Patrick
West Palm Beach
06 F150
What type of rail do you add the IAG step to? Is this the ford oenology rail?
Mattyfly42
2021 4 door 2.3L MT
I am getting the Full length to protect with rock chips. Think its just another layer of protection.
70&22bronco
70&22bronco
Fallon
1970 Bronco
I’m not sure what the rail is called, but they attach to the OEM rock rails that come stock on the BD and BL trims.
70&22bronco
70&22bronco
Fallon
1970 Bronco
I edited my first post to add this information.
I went with the full length steps. I was worried they’d cause too much of a lowering effect on my stock BD, but I don’t think it made that much of a difference. They are definitely in the way of my husband (6’3) getting in and out. I’m 5’10, and while they aren’t in my way, they are a little awkward for me to use (they set me up too high when getting in, but they help prevent me from sliding off my seat when I get out). They are perfect for my girls (11 and 5 years old). I think they only thing I wish would’ve been different, appearance wise, would be to have them run the same width the whole way through.
Ford Bronco IAG V2 Steps 2185769C-8019-496F-85F3-2F32A7837546
Ford Bronco IAG V2 Steps D2652B05-46C7-4C81-9A28-48D2762711CB
Ford Bronco IAG V2 Steps 1BF553D5-96E7-4CAE-B7B8-6721B4A976F6
Aloha Sunrise
Hawaii
2021 Toyota Tacoma TRD off road,1971 VW shorty bus
I’ve had mine off a couple of times, no damage at all. IAG uses a neoprene like material on the brackets that clamp to the factory rock rails.
BroncoAZ
Mitch
The screw will bite into the back side of the step. I fitted some stainless washers and neoprene washers where the screws hit the factory rock rails. I was concerned about rust over time.
mikejames
Canada
Bronco Black Diamond 2 door
I had this thought too. Haven't pulled the trigger on the steps yet. How did you arrange the washers to prevent the screw scratching through the powder coating?
BroncoAZ
Mitch
The stainless washers were small enough that the studs securing the step could center on the washer hole but not go through. The neoprene washer went between the stainless washer and the factory step.
mikejames
Canada
That's an excellent idea! Did you glue the washers together or just let pressure hold the neoprene in place?
BroncoAZ
Mitch
Pressure was enough. When I removed the steps after some number of months to swap to the Greenlane aluminum steps there was no damage to the factory sliders.
geargeek
Houston, TX
23 Bronco HE, (also owned and sold a 21 Bronco Sport BL)
How are you liking the Greenlane aluminum steps?
BroncoAZ
Mitch
They are sturdy and look good on the truck. The powder coating is holding up well, they still look like new. I haven’t tried using them as rock sliders, I would expect damage if I do in the future. I would like Greenlane to expand their aluminum offerings for the Bronco. A light weight winch bumper or mount and a similar rear bumper would be awesome.
