I would rather have a nonremovable roof.
I would rather have a non removable roof.
  • Total voters
    595
TonyWonder
AL
2011 Nissan Altima
Given the hard tip fiasco, would there be significant demand for a nonremovable roof?
And make the rear window roll up and down into the door. Then we’re talking about competing with all those Toyota 4Runner die hards too.
Just a thought.
I have zero interest in this vehicle if the top doesn’t come off.
dgorsett
colorado
F250, Mustang, Explorer
Except you would be missing...
Removable doors
Ground clearence
Lockers
SBD
Approach and departure angle
Breakover angle
33", 35", 37" tires
Winch bumper
Rock rails
Bash plates
Coil overs
Goat modes
Roll bar
Trail cam
I'm sure I missed a few.
solid rear axle
reasonable trail dimensions
and yeah North 7 said it, but ground clearance
..and, my favorite: low range
and did we mention ground clearance?
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
Just a thought.
I just threw up in mouth a little bit.
khatch
Kevin
Ford F150
"I would rather have a nonremovable roof" :unsure: Yes you should cancel and buy a car with a non removable roof.... if that was the question. ;)
bdub2you
Alexandria, VA
Non-removable roof? So...you're looking for something like this then?
Ford Bronco I would rather have a nonremovable roof. land_rover_defender_n
Designkid
Kris
New Jersey
2021 Bronco Badlands
Ford Bronco I would rather have a nonremovable roof. 1622597564738
bdub2you
Alexandria, VA
Is there a decent looking version? That one is awful...
To each their own I guess. I'd take the blue Defender with white roof over an FJ Crusier any day of the week, but it doesn't matter since my Bronco is being built next month.
imaginager
PDX / Oregon
2021 Bronco Black Diamond
Back in Y2K times I had an IHC Scout II cab top custom built - frankly, I wish I'd never sold it. But, a back surgery in 2003 pushed me into something with soft suspension. The IHC's cab top was light and easily swapped for a bikini top. This Bronco was engineered to have a removable top. I get that, maybe, 20-25% of people will never take the top off. But, the draw for me is that it's removable - if it wasn't I'd be shopping for vintage.
Daktari
Oliver
easy solution, just tack weld the bolts holding the roof to the body and use a good epoxy to glue all the roof panels on, problem solved. ;-)
If the roof didn't open up, I'd not even be looking. I doubt I'll ever take the rear shell off (unless I find a nice soft top I like), but the front panels will be off quite a bit, that's what sold me on the Bronco. I might take the doors off once to just give that a try, but there are no beaches here to drive on and any fun place is a good distance on the freeway from me, doesn't sound like fun with no doors. Plus I like my arm rest.
But maybe aftermarket someone will make an other roof. Ursa Minor is working on a top with integrated RTT for the Bronco, so that will be somewhat permanent. And you can sleep in it and get into your RTT from inside the Bronco. Expensive, but pretty much the only RTT I'd ever consider. Which I won't, because I want to open my roof and not look at a tent or roof rack or gas cans or recovery gear, just blue sky.
VictoryLights
Pittsburgh
2018 Honda Pilot
Why would anyone be here without the removable roof? Unless you’re just a ford/bronco fanboy it’s insanely dumb. You can go buy a 4Runner right now that will without a doubt be more reliable and cheaper.
The only differentiator is the open air experience.
