How to turn off wireless charger
motoring
Keith
Seattle
13 MINI GP
Mine doesn't work for shit, hardly charges and makes the phone unbearably hot. (android user)
For those that the charger works, what was your build date? maybe ford made a change. Mine was mid December.
Mgro
Matt
NY
4runner
There's a menu item in features to turn it off. Mine was turned off from the factory and I've never turned it on.
Can you guide us a bit? I can’t find it by clicking through…
JD11937
Joseph
East Hampton, NY
Can’t you just flip your phone around so the front is facing the charging surface, then it won’t charge but still a good spot to store the phone.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
I know I'm old and everything, but what's the big deal about having the phone plugged in an charging via the USB jack that's right there. The phone is out of the way. It charges fine. All the CarPlay functions work fine, and the USB cable doesn't take up any space. The whole wireless charging thing seemed pretty gimmicky from the start and absolutely seems to be more trouble than it's worth. I have to keep my phone in an OtterBox anyway so the wireless was never going to be an option, I just never understood it's allure.
Erock
US
2018 F150 Alpine edition
I use a cable and put my phone on top of the steering column… perfect fit with no sliding around or anything.
MikeyFrog
Iowa
Interesting! Never thought of that location
cgv
Apex, NC
Bronco Badsquatch, Explorer ST
With android auto running, the wireless charger can't keep up with my phone. If I go on long trips, I have plug it in or else the battery will die.
Someone needs to figure out how to upgrade the charger to something that isn't a total POS!
Osky305
Osky305
Oscar
Miami
Wildtrak Bronco
My wife bought me some nice thick inserts to dress up that cubby along with the cup holders. The one for the cubby effectively keeps the wireless charging from happening (combined with my phone case).
Where did she buy them ? I want to get the same. Post link
NC_Pinz
Central NC
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
This smells like a class action lawsuit...
Fmcnick
Fmcnick
F-250 Tremor
Topic - Wireless charging pads in most Ford vehicles.
I see quite a few threads for disabling unplugging the charge pads.
Removing fuses / removing panels to unplug it at the module / placing phone face down etc.
Seems some have trouble with certain phones and how hot they get or other various reasons.
My daughter just got her License and SUV a few months ago. Has an iPhone with case that stores her credit card. HAHA well Card is warped / deformed.
She had the card and a foil wrapper in the case. Lesson learned. - In her Ford that pad is about the only place to put the phone in the console.
So, I looked for options to just disable the pad. Or disable wireless charging from the phone or vehicle.
But if it had just a bit more space between the phone and pad that would keep it from charging.
A bit of thinking .... And here is the KISS Fix.
Mouse Pads / Desk-mats. These are cut really simple with some scissors.
I happen to have a bunch of these. I picked out one that has the Microfiber cloth face with Rubber back. Its 4mm or 1/16 inch thick.
Some newer pads are thinner and may need to be stacked to 4mm.
Once it was trimmed and dropped in place on the charging pad problem solved. Neither the iPhone nor the Samsung activated the charge pad.
Easy enough to pop out and use charging / or drop in pad and bypass the charging.
Well, it was a fun problem and just thought I would share my Dumb Idea.
Think I have only used the charge pad in my truck 3 times. I prefer my mount and Cable so I can still access My Camper and Camera Apps when needed.
Bronco_Guy
Illinois
2024 Bronco Raptor - Azure Blue
Can anyone confirm that if I just unplug the charger, that the Bronco won't throw a code?
I've been in there and installed some higher output ports, but thought twice about disconnecting the charger for fear it would throw a code.
The plug had at least 4 if not 5 or 6 wires going to it so I wasn't sure if it would be ok with being unplugged. Not just a positive and negative that the car wouldn't even know if they weren't being used.
If nobody knows for sure, I will just bite the bullet and take it all back apart and test for everyone.
