How to Turn On Ignition Without Starting Engine?
RideEmCowboy
RideEmCowboy
Portola Valley, CA
'95 Mustang,'08 Honda Civic,'03 15hh QH Paint mare
When I first had the push button car, for the first 15 minutes I could not figure out how to start the engine until I tried putting my foot on the brake. I was like DOH! :ROFLMAO:
I went from a '95 Mustang to my '22 Bronco. I felt like an idiot not being able to start it, however, there is a message that comes up on the screen, like, "Ignition for Dummies."
JohnnyMotorBoat
Austin, TX
Ford Bronco Wildtrak 2 Door
As others have mentioned press the Start button once without Foot on the Brake will put it in the ON Mode, with headlights, A/C etc. Press it a Second time without Foot on brake and it will change it over to ACC mode saving the battery.
It's the second bit that isn't working on mine. If after starting in accessory mode I tap the start button again without foot on the brake, it just turns off.
da_jokker
Jeep Wrangler JKUR
Unfortunately I can't try this myself yet, but it's some of the other brand cars I've had, if you place the transmission in neutral when you shut off the car it will leave the radio on (And of course you can put it in the park).
I always thought it was handy, for example listening to something when you get your destination and you want to shut your car off without interrupting the radio.
