How much can it really tow?
Eruption883
Montreal
‘78 F250 camper special, ‘19 GT3 RS, transit van
Hey all,
I’ve seen some threads about towing capacity, usually asking about boats and weights of around 3000-3500lbs. I’m looking for opinions or experiences with towing more than that with a Bronco.
Eventually my Badlands with the 2.3 7sp (non Sasquatch) will arrive, and I’d love to be able to sell my (way too big) ‘07 Sierra 2500hd. I used to tow all sorts of cars all sorts of places, so needed that behemoth, but now I tow is a 1500lb aluminum flat deck 22’ trailer, with a 3000lb race car. No big mountains, or crazy distances. Some hills for sure, but we are talking laurentians mountains, not the Rockies!
Of course I know it’ll be slow, and I won’t be passing anyone going up the hills. I do have a lot of trailer experience, and the trailer has brakes. Will be adding an aftermarket electronic brake controller to the bronco when it arrives.
Thoughts?
Pics of the trailer, current tow rig. And what I’m hoping to tow.
(And yes, I know it won’t even be in the same league as towing with that HD monster.)
Ford Bronco How much can it really tow? 48845892-A376-4B8A-B8B4-A50095B6A8E2
Ford Bronco How much can it really tow? FDED4C86-38B3-44E7-9514-838AB603581D
MnLakeBum
MN and FL
‘18 Range Rover Diesel
Unless it's a very short distance, I wouldn't tow 4,500 with a Bronco even if it had the 2.7Liter.
If you don't want the huge truck anymore, maybe look at something like a used Grand Cherokee diesel. I think the towing capacity on that was 7,200 lbs.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I wouldn't, just to much for the suspension. I think the brakes, engine and frame are 100% up to the task the limiting factor would be hitting bumps and having the trailer push the rear around. It's more of the leverage that a longer trailer can put on the hitch.
Side note, I use to tow a lot with my Fzj80, I went heavy springs to better tow. I would wait and see if aftermarket makes some overland springs if you decide to. 1-2 times I went way overweight I finally found the limits. Yes I have moved farm equipment that my Grandpa shouldn't have bought at auction way to many times...
Laminar
Iowa
Cougar
I feel like there have already been 1000 threads like this. Will the Bronco pull it? Of course. Will you be absolutely fucked sideways if there's any sort of accident and it's found that you were exceeding the manufacturer's GVWR? Also yes.
tobands
2022 Bronco OBX , 2024 Edge ST
My 2019 ford ranger has a 7500 # towing . May be a better choice for your needs.. IMO the bronco is just not the right tool for any serious towing..
Eruption883
Eruption883
Montreal
Thanks for all the feedback. I’m trying to downsize the fleet of cars that I only use on occasion, and since I only use the racecar three or maybe four times a summer, the giant truck would be the best one to go. So while yes a jeep grand Cherokee diesel, or a new Ranger would be better suited for the towing job, neither would do the job as well as the vehicle I already have for that. Essentially just hoping the bronco is tough enough for some occasional heavier duty towing for its weight class.
I know, problems, right? Too many toys and not enough time. Or space.
Concerning GVWR and accidents, of course that’s a given. Was simply wondering if people had done it, and how it went. Considering how low the tow rating is, and how as someone else pointed out a ranger can be set up to tow 7500lbs, I guess I was curious if it was just Ford sandbagging so that I would ALSO buy a ranger or F150. I mean, you’d think a Bronco could at least tow itself (like say your buddy) out of a bad spot, or home a bad day. Not hating, just genuinely surprised that max tow rating across the board is 3500lbs, which is super low.
Rick Astley
Up Doug's ass
d
Keep the truck. U will ruin the bronco. Its only 4 cylinders, bless its little heart.
What the heck are you talking about? the 2.3 pulls 13,801 lbs in Ranger just fine.
How much you "can" tow with a vehicle is probably about 105-110% of the claimed max tow before things start to go pear shaped. But as always, the devil lies in the blood and insurance claim. Overload the rig, have a failure and hurt someone and you're likely getting that claim denied.
For Big Jim who needs the visual that 13,801 > 9,867
Towing comparison (using max weights)
Bronco (Badlands)
Curb weight4,997
Towing capacity3,500
Max cargo1,370
Max payload9,867
GVRW6,160
Ranger
Curb weight4,441
Towing capacity7,500
Max cargo1,860
Max payload13,801
GVRW6,050
tobands
for the bronco low tow limit I think it's mostly because of the coilover suspension is just too soft for a heavy tow . a heavy load would squat the heck out of it and make a unsafe tow
tobands
Also from what ive seen the reciever hitch does not mount to the frame directly but to a cross member
Eruption883
Eruption883
Montreal
The trailer is quite long, but dual axle, and the car sits with most of its weight essentially on top of the axles, keeping the tongue weight very low. As long as I can get it level with the right drop down, I don’t see why the tongue weight would be excessive. I also would probably skip putting the extra set of wheels on the wheel carrier way up at the front of the trailer for the same reason. But would remain that if I did this, trailer and car would still be about 4500lbs, which is well past the rate stow limit.
Eruption883
Eruption883
Montreal
Ah, that might then be a pretty solid reason for the low limit. Did not know that.
Thanks.
DogHauler
Chuck
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
Towing capacity on the Bronco is less than the Maverick, keep your truck.
tobands
i have no doubt the bronco can tow your setup but can it do it safely and without damage to the bronco
Thanks.
Ford Bronco How much can it really tow? 13493_1
Baja71
Stroppe
tw
Dallas, TX
1971 Stroppe Baja
Stroppe
That and the fact that it doesn't really have a roof. Bad juju in a rollover, and when things go bad pulling a trailer, they can go really bad. I vote no., JMHO
