How good will Bronco aftermarket support be?
elfshadow
Jeffrey
Ohio
Jeep Liberty
I'm guessing the aftermarket is quite robust for the Bronco. Not too worried about aftermarket support.
Corsair
Jacob
San Francisco
Escape
The modularity that Ford incorporated into the Bronco should ensure that aftermarket companies will be tripping over themselves to provide products.
DonsBronc
Don
2017 GT350
The aftermarket is already huge for the classic broncos, so you know those companies will also support the new bronco, plus all the Jeep aftermarket companies will jump on this market, it will be huge
mC.242
2021 Big Bend 4dr (sold)
Lockable storage units in various areas.
This is a big one for me - I will be looking for a security box/drawer/deck type solution for the rear cargo area since I'm getting the soft-top. I know I can easily make something that will get the job done for a while, but will eventually want something better.
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
cnhendricks93
Nate
South Carolina
1995 mustang gt 1991 mustang gt 1953 F100
When I look at trims and which model Bronco that I want to get, I start to think about the after market parts that will be available. I have had three mustangs in the past. When I think about a stock mustang, I feel like it is no where what it should be until aftermarket parts are added such as an intake and aftermarket wheels. There is a huge aftermarket for them with many reputable companies. It is so tempting to want a fully trimmed Badlands, but I really am curious if broncos will be like mustangs in that the after market will be so much better than what the factory can offer. I know factory warranty comes into play, but will it be better to go base and add the aftermarket goodies like a mustang, or is factory accessories the best route. I guess only time will tell.
Philly
Dallas, TX
2022 JL Rubicon
I think it is really going to come down to what you are trying to get out of your Bronco and which parts you are adding/replacing.
If you are going to beat on this, then I don't think you can do much better than a factory offering for suspension and drive train modifications. They will offer the most support when things break.
If you are going to use it predominantly on road, then you can probably get away with cheaper aftermarket stuff that would be "better" for you from a value standpoint, but I would make sure there is a good warranty.
If it is not suspension or drive train related, it will probably come down to personal preference and cost. Take lighting for example. Ford is partnered with Rigid, but some people may prefer KC or Baja Designs. They all make good products, but at this point it looks like you will only be able to get Rigid from the factory.
Blitzinger
New York
Tiguan
If the wrangler aftermarket is any indication, there will be a ton of options in the months to come after the Bronco is released. One mod I recently found for the Wrangler that I hope will come to Bronco at some point (even though its quite expensive) is a bolt on extension to the back.
Wrangler has one and it really expands cargo space for the ultimate overland build.
https://www.americansafarijxl.com/?...kHRkWlNFcnxy0S73eoN9rAedHBoRKXHcaAiOeEALw_wcB
But like I said. Pricey ($17k-18k I think I saw)
Edit: Should mention that the expectation of a large aftermarket scene is why I'm going Base.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Yes, much like Jeep, the aftermarket will take the Bronco far beyond anything the factory could produce. Comes down to how deep your pockets are.
Or you how deep are your pockets each time you replace something over the life of ownership.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
I just want downpipe, intercooler, fuel Pump, rails and other fuel management for E85 conversion and a Cobb accessport tune, just like the EB Mustangs do. There will be so Many Broncos. The aftermarket should be huge.
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
Can't speak to the new Broncos, but if the Early Bronco offerings are any indication, there is a huge aftermarket for Early Broncos.
Felix808
SRV CA
There went the rear departure angle.
