How do you replace the license plate light?
Tdubz
T
F
The license plate light on my rear bumper is cracked. I have the replacement, but I don’t see a way to take off the old one. Anyone know how to remove it?
ChrisB351
Shreveport, LA
It has a tab on one end and clip on the other that hold it place. Has a plug. Should be able to pop it off with a small screwdriver.
Lowcountry Bronco
William
South Carolina Lowcountry
From a quick google search ...
Just the first part is all you need to swap.
orion
Jeremy
17' F-250, 17' Explorer
I'm sure @flip will get you what you need!
ChrisB351
Shreveport, LA
Better search again cause that has nothing to do with his question. He was asking how to replace the license plate light.
Tdubz
T
F
I watched a video of the light being replaced on an f150 and its light had a little slot that you could put a screwdriver in to pop it up. Unfortunately the bronco light doesn’t have that slot.
Lowcountry Bronco
William
Well heck, I read brake light ... Sorry OP!
flip
Phil
IN
www.ruxerparts.com
Fords
Ford Bronco {thread} {filename}Ford Bronco {thread} {filename}
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Using a non-marring tool, release the tabs and position the license plate lamp out.
    Use the General Equipment: Interior Trim Remover
  1. Disconnect the electrical connector and remove the license plate lamp.
Installation
  1. To install, reverse the removal procedure.
Beachbum
Lancaster, PA
2023 Bronco
Is that a special bulb or does someone have a part number? The dealership wants $60 to replace. Seems kind of steep.
Thank you
