How are you mounting your recovery boards
Midlife Crisis
August
Missing my 86 Bronco
While I can appreciate wanting to mount your boards inside of the vehicle, use them in mud and you may be rethinking that. My current set up:
Ford Bronco How are you mounting your recovery boards IMG_2260
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
msujay2012
Indy
2023 Ford Bronco Wildtrak
My wife asked me to stop mounting my recovery boards (god knows they are sexy) so now I throw them in the bag thingy they came in and in the back they go.
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
telenerd
Laramie
Subaru
Simple solution for my 2 door. Straps fit nicely on molle with seats down. I have the action trax. They are probably the best boards I’ve seen because they are rubbery and won’t chatter in my car while on the trail. I’m cheap and carry a trash bag to put them in if they get muddy. Easy to wash boards when home.
Question should I get another pair? Most folks I’ve seen only have one pair.
Ford Bronco How are you mounting your recovery boards F8B39610-8952-4E11-908A-524D64018AE0
  • Like
Reactions: GAN
Mortonm
Canada
2022 Ford Bronco Black Diamond
Two rok straps and as easy as that. This was the test fit so I'll need to mount them a little higher to avoid strikes.
It blocks a very little bit of the backup camera but not much.
Ford Bronco How are you mounting your recovery boards 20230406-131723
Ford Bronco How are you mounting your recovery boards 20230406-131704
vrtical
Doug AI
GSMNP, TN
Fords
Ford Bronco How are you mounting your recovery boards 1685121764689
Bringing this one back up. Just ordered the Ford Performance ones ( M-1820-FPRB ). The trick is to buy them from the Ford Performance site then it dumps you into the Ford accessories site where you can apply the discount they are running and use your points if you have some. You can't search for them on the Ford accessory site. next up will be to figure out how I want to mount them, not sure if they will fit behind my M2M cage setup behind the seat. May mount them to my shelf instead.
GroovyGeek
Boyan
'23 Bronco BD
Why isn't lashing them to the soare an option? Costs nothing if you already have 2 lashes lying around. Mine are the TRED shorties from around 10nyeaes ago and they fit really nicely over the camera. The MaxTrax should fit too
Ford Bronco How are you mounting your recovery boards STP8_20231028_121720753~2
Imonamoose
Moose
Earth
Truck
In all my years I have never seen recovery boards recover anyone or anything that could not have just been accomplished more simply with proper tire pressure. I have never seen an actual use case for them on the trail or in the snow and I'm starting to be believe that no one has....
If you are actually stuck you need a winch or a come-a-long and the recovery boards only ever actually get used as annoying shovels. 🤣🤣
Magic
Ford F150, MME-GT PE, BRaptor, Other Ford Cars
I mount mine on the side using my TrailRax setup and some hardware items from local Ace Hardware store. Side mounting plate is positioned back so the tracks don't interfere with opening the back passenger door and can open the back window/door with no problems.
Ford Bronco How are you mounting your recovery boards Gary TX DL Front resiz
Ford Bronco How are you mounting your recovery boards 20230607_204832 resiz
Ford Bronco How are you mounting your recovery boards 20230607_204756 resiz
Ford Bronco How are you mounting your recovery boards 20230607_204805 resiz
SwampCactus
These fit perfect just above my Baja Reverse Lights so I still have the function of that and my camera. Just attached with 2 perfect bungees. Can also run a cable and lock them to my propane mount.
Ford Bronco How are you mounting your recovery boards Screenshot 2023-11-29 at 12.20.10 PM
KABQ
Aaron
Albuquerque, NM
Made a mount out of a piece of scrap i-beam from work. Mounted the boards high so they don't limit departure angle, and as long as I don't open the tailgate past 90° they don't hit my taillight.
Ford Bronco How are you mounting your recovery boards PXL_20231126_184441674
Ford Bronco How are you mounting your recovery boards PXL_20231126_184506318
Ford Bronco How are you mounting your recovery boards PXL_20231126_184435495
