Hossfire's budget-friendly B&O build
Hossfire
Ken
Richmond, VA
'06 Jeep Commander
Note, If I had to do it over, I would have left the kick panels stock and replaced just the dash speakers with Polk db402s ($50) and the center channel with the PRV audio 4" midrange ($19). I spent far more money on the front and frankly it was a waste. So, all of this can be done for less than $1000.
So, the front channel is what I recommend, not what I did. Also, add your applicable sales tax. These are today's prices. I paid a little less for some of them (inflation).
Here's what I did and why:
Neither the base audio, nor the B&O is loud enough to overcome road noise with the roof panels off. Bronco picks up a ton of road noise at highway speeds as well. If you really want to hear your tunes, adding an amp is the way to go.
Also, the bass from the 'subwoofer' is better than nothing, but it's crap. Harmon's amp is very low powered. In order to get any sound out of it, they use a highly efficient neodymium driver that has no low end. They use 'bass roll-off' in the DSP to prevent you blowing the speaker at higher volumes. For that reason, feeding an aftermarket sub amp isn't the best solution. The Kicker Key 500.1 is supposed to address this, but I've never used one.
You will also want to replace all the speakers with aftermarket and swap out the rear pods with aftermarket 6.5 pods as I mention below:
So, here's the deal with the amp sub combo:
  • Even if you replace your kick panels with the most efficient 6.5s on the market (I did---Hertz SPL line mid-range) they are so awkwardly placed, you really can't hear them with the crappy Harmon amplifier in the B&O system.
  • If you feed the rear pods from the kick panels, you lose fader controls. You will want fader controls with an amplified system. It takes a lot of power to the rear speakers to overcome wind noise with the top panels off. With the top panels on, you don't want that much power---it makes your system very rear-focused. Heck, I grew up on 6x9s in the rear deck of my car. I don't mind so much. Most people would be really bothered by it, Anyone riding in the rear seats would hate be blasted out with the roof panels on.
  • The rear pods have a high-pass filter built into the factory DSP. I think it kicks in at 300Hz. Unlike the base audio (correct me if I'm wrong @RagnarKon ) there is no dealer flash or Forscan setting to turn the filter off.
  • Using a full range amp with a high (320Hz) low-pass filter allows the sub to "fill in" the mid-bass frequencies that the Bronco is missing. Unlike many aftermarket subs, the Pioneer can hit these mid-bass frequencies with ease.
