hoss 3.0 rack programing issues
vrtical
Doug AI
GSMNP, TN
Fords
Use Forscan to populate the dummy VIN into the BCM (I think it's in the BCM)
Use FDRS to program your rack
Use Forscan to populate your actual VIN back into the BCM
Clear all codes and drink a beer
I like the the last step.
aldoavme
adam
Bluffton sc
2017 f350
I had the same issue on my 2022. i have the ford programmer and downloaded the software for the rack but same thing wouldn't work. So i call ed the ford performance number and had a ford specialist log on my computer and change a bunch of code he says its a bug with the 2022 builds
they were super helpful
Yeti BD Sasquatch
Jose
CA
2016 Tundra
Hopefully my tech can get it done
Thank you for the information
Yeti BD Sasquatch
Jose
CA
2016 Tundra
Are you back in business?
No sir been on the phone with Procal to see what they can do
Took it to a buddy shop he was able to download the stock rack file but the new rack won't take it IDK
Shrek27
Fullerton CA
Oh man, that sucks! Would your old rack even work at this point I wonder, just to get you on the road?
Yeti BD Sasquatch
Jose
CA
2016 Tundra
I might just return this rack and go back to the oem Hoss 1.0 lol it lasted 75k miles
It just blows that the dealership have no idea what they are doing
userdude
Denton, TX
2023 2dr Badsquatch
Did your friend try to install a known VIN from a WildTrak or Badlands with HOSS 3.0? Your stock BD rack programming won't work, but he could trick it with a VIN that does work.
Shrek27
Fullerton CA
@Snacktime has said that the FDRS method works on every model right now and you can easily program the rack with a $100-200 adapter and $50 subscription. So may need to spend more to make it work vs. undoing your labor hours and ending with the inferior setup.
BigMeatsBronco
Allan
2021 FE 2 door
why don't you have them follow instructions on the correct thread here...? My rack-hack has worked flawlessly for several years, for EVERY bronco.
feel free to PM me.
Yeti BD Sasquatch
Jose
CA
2016 Tundra
At this piont I'm down to spend more money, need to make it to UBB with my crew lol
What adpter do i need? And are talking about Forscan subscription $50
Shrek27
Fullerton CA
No its an FDRS sub. @RagnarKon did a video at one time saying you can get a 3 day sub for $25
I've saved these in my bookmarks for the day I attempt this. Have heard they all work.
https://www.vxdiagshop.com/wholesal...EY32KyMMfJh_x0tu-vTVi_4j1kwYCSRx62Nf7zHunhzF9
https://www.amazon.com/TOPDON-RLink...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
https://www.amazon.com/dp/B097NHQ7Z...=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM&th=1
BigMeatsBronco
Allan
2021 FE 2 door
He's still gonna need forescan to do the VIN swap tho...!!!
