Hoss 3.0 on 2.3l non sas 2 door
Fordsoldier
MIdwest
2024 Bronco 4 door Wildtrak high lux
OK guys. Im thinking of lifting my bronco wildtrak. The eibach springs was on my list but I only have 3/4" difference from front to back. 38.5 in front and 39.25 in rear. It would sit higher in front according to the amount of lift they produce I dont want that. So looking at eibach coilovers. To lift it evenly front and back
Back to my question. Can a 4 door hoss 3.0 system. Be put on a 2.3l 2 door if the 2 door springs are reused on the hoss 3.0 shocks. Was going to put them on my wifes 2 door non sas badlands if it would work.
Hope this make sense thanks in advance
23OBX2.7
AB Canada
2023 Bronco
I don't see why not when using same springs...
Fordsoldier
Fordsoldier
MIdwest
I just want to make sure it wont mess with the valving
6glifter
Richard
New Jersey
12 fusion 94 lightning 94 ranger 89 mustang
Yes you can use swap the springs over i have a 2dr 2.3 7spd and I have the hoss 3.0 with 4dr springs due to added weight from winch and stuff also lifted about 4in with perch collars in front to level it and top hat spacers at all 4 corners until I can afford adjustable coilovers it all work well for what it is
GI_Jo_Nathan
Jonathan
I would just bolt them on as is first and see how you like it. Most seam a little soft in the front and have excessive nose dive. Might level it out a little as well. Then if you don't like it go through the work of swapping springs.
