Horn location?
Cavallo11
Johnny
USA Florida
Does anyone knows where are the horn located?
Thanks
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Behind the passenger headlight.
Winds of Change
Chicagoland
2022 Bronco Obx SaS/2021 Bronco sport Badlands
Does anyone know where I can access the main wire before it splits to the two horns? I want to add a switch to use either stock horn or aftermarket horn from the steering wheel.
Ducati1098
Splice S131 is where it splits off. It’s near the LH horn. So it would need to be between that splice and where it comes out of the BJB.
Ford Bronco Horn location? IMG_2626
Ford Bronco Horn location? IMG_2625
Winds of Change
Chicagoland
Thank you. I also just found the zip file someone posted. I was in the process of downloading everything.
Winds of Change
Chicagoland
It looks like it could be a lot of work to access the wire I need and where I need it. Might not be worth the work.
Ducati1098
Yeah depending on where exactly the splice is in the harness, it doesn’t look like there is a whole lot of room to work with between it and the BJB
Johnny Mo
Westchester County, NY
teachu2shoot.com
I did something similar for my airhorn setup. I got the matching connectors so I could do a no cut/no splice installation. You need to pull the grill, lower valence and both headlights. The horns and connections are right there then. Let me know if you need more info (I'll dig up the part numbers for the connectors if you choose to go that route - unfortunately I don't think I took too many pics of the horn setup at the front. I set mine up to switch off my air system and horn using an Aux switch.
https://photos.app.goo.gl/XEXxqHkY2Q4qJihQ8
Winds of Change
Chicagoland
Just knowing its accessable by removing the headlight helps alot. When I was installing the winch I wondered about it. I had the grille and valence off and looked at it. I just did not have the time or ambition at that point to go the next step. Thanks. The part number and where you got from on the connector would be great.
Johnny Mo
teachu2shoot.com
https://www.cycleterminal.com/molex-mx150.html
Where I got the idea:
https://www.ford-trucks.com/forums/1702521-2022-f-250-horn-relocate.html
