Hood / Fender alignment
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Finally got a chance to check out a Bronco in person at a local dealer. While I was pleased overall, the hood/fender alignment immediately drew my attention. It was even more obvious sitting inside. Is this really "Normal"? Both sides were the same. Also note the dents on the hood. Based on other reports of dents. I really hope these hoods are not so easily dented.
Ford Bronco Hood / Fender alignment 08CC603F-0EAB-49B6-9510-F9358F0133A2
Ford Bronco Hood / Fender alignment 7632647E-134A-45FC-951C-B79FEFFD3A2B
FourHorses
Four Ford Horses and an Expedition
Mannequin model I looked at was exactly the same on the hood to gender gap alignment. :confused:
D-TownBorn
Josh
2018 wrangler unlimited
I test drove one yesterday and was surprised how obvious that was from the drivers seat. I searched on here and found this thread to see if it was normal. I was not a fan.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The WT I test drove looked the same. Unfortunately raising it up will leave a gap at the grill, so maybe the design was intentional.
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Since it appears to be normal, have to wonder if it has to do with with countering a whistle or something.
DallanW
Santa Monica
Ford Bronco
Mine has the same thing, hood sits below fenders, one side about a quarter inch and the other an eighth. If I try to adjust it even a little up the hood ajar alarm pops on.......So guess it is supposed to be that way. Brand new.
omi205
BoJack
Austin
Yup. My 2023 is like that. I dont mind it as long as its equal on both sides and it is.
Smokey142
Andrew
2008 Z71 LTZ
Adjust the rubber bump stops that are under the hood at the front corners. They just screw up and down and will raise where the hood sits and also stop the hood flutter when driving down the road.
