Hill start assist question?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I apologize if this has been covered elsewhere, but I have scoured the forum for an answer to what I think is a kinda simple question. I understand that MT Bronco will have "hill start control" or "hill start assist" which locks the brakes while the clutch is disengaged and the vehicle would normally roll backwards because of its attitude on a hill, or let us assume, any type of uneven terrain. I can forsee situations where I would both want and not want this feature when wheeling. Is there an EASY way to quickly turn it on and off? Or do I have to scroll through touchscreen menus and do a bunch of foolish things...in which case I will just lock it out permanently?
The Pope
1977 F250/2007 Mercury Mariner/2014 Infiniti Q60x/2011 Kawasaki C14
I've wondered this as well.
There's a Park Brake discussion within the Wheel, Tire, Brake section and that's most likely where this thread might should be.
Spooled
Republic of Texas
Raptor, Model 3
On the Mustang it's extremely easy. From the gauge cluster screen you go to:
Main Menu > Driver assists > Hill Start Assist and check it on or off. Takes 5 seconds. at most.
Bmadda
Bmadda
Wisconsin USA
Thats acceptable I suppose...a "hot button" would be nice, but I can make that work once I get used to it!
Bmadda
Bmadda
Wisconsin USA
Does the hill start assist use the parking brake or the service brake?
The Pope
No clue....
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
My '14 civic has this feature and if you put the gear shift into neutral it will roll backwards with the clutch pedal down.
Bmadda
Bmadda
Wisconsin USA
That may be...but I'm thinking off road technique here. One of the cool things u can do to get up an obstacle off road is jog the clutch to hop the vehicle. I see jeep guys do it alot, and I've done it w/my yj...course its a little bouncy on leaf springs. If I'm doing that I'd want the brakes to stay off. If I'm crawling and suddenly have to stop it would be nice to have the brakes help me. Its not something I gotta have, but if I'm getting it anyway I might as well learn to use it and when not to!
vrtical
Doug AI
GSMNP, TN
Fords
on the mustang parking brake is still cable so uses ABS system up front. guessing it will be the same on the Bronco 7MT. Also there is the new trail control feature, but that is an A10 only addition.
myrlin16
Justin
IN
Ford F-150, Audi TT, BWM 228i
I've driven several Ford vehicles with Hill Assist and have it on my current F-150. The hill assist doesn't engage until you press the brake pedal and come to a full stop on a hill. Once you release the brake pedal the hill assist keeps the brakes engaged until you've applied enough acceleration to start moving forward. Once you have the vehicle moving, if you lay off the gas, it will roll back down hill.
So in essence, you can have it both ways. As long as you never apply your brakes on the hill, the hill assist won't engage. If it is already engaged, you can turn it off by applying a little gas.
Not sure if this is how the Bronco will work, but seems like a reasonable assumption that it does.
crowdpleazer
Daniel
West Virginia
I see your point here. Not sure what would be best. As said above I'd imagine it wouldn't take long to navigate through the settings menu to turn it off. A hot button like traction control would be nice but I wouldn't hold my breath. (hoping for a couple extra buttons that can be user programmed for stuff like this would be sweet!)
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
Also the hill assist has a timer on it - if you take your foot off the brake it's only a matter of seconds before the brakes disengage. So you can have it both ways without going into the cluster, as long as your patient.
The Pope
I hope that FoMoCo will still provide a Manual Hand Brake Lever with the Manual Transmission.
Bmadda
Bmadda
Wisconsin USA
I thought they went to electric ebrake? Or did I miss something?
The Pope
We don't "officially" know.
If it's only electric ebrake, that would be another strike against the Bronco for me, as I want something that I can manipulate in real time as needed while maneuvering around obstacles.
