Hi-lift jack points?
Clint
Clint
Columbus, OH
VW Jetta TDI
If you get a Bronco with front and rear metal bumpers and rock rails, where are your jack points for something like a Hi-lift jack?
I would imagine the bumpers being ok, but the rock rails are something I definitely have no idea about. The rock rails seem like they hug the body a lot and might be hard to get a Hi-lift jack under.
KH_59
Kevin
pearland tx 77584
F-150
A
Are you planning to get an aftermarket rear bumper (since you can't get a metal rear bumper on a Base)? I think you are right that the rock rails would not be appropriate as a Hi-Lift jacking point.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
It does look like the rock rails are too close to the body.
There is a hi-lift accessory that lets you lift from the rim of a tire. Very useful if you're stuck but not so useful if you need to change the tire.
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
A
If I stay with the Base, I will go with an aftermarket rear bumper that has lifting and winching points. I am still thinking about the BD though.
Rivers90
Ben
Southern California
The aftermarket will have much better bumper options and bumpers are easy to swap.
It is cool you can get a metal bumper from the factory. All the bumper most people need. But bumper upgrades have always been huge in the 4wd community.
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
I guess it wouldn’t be that bad if I got the BD and the only thing I had to do to it was swap out the rock rails for a set of rock rails that had a solid jack point.
Charky
Duane
Little Rock
A7
I believe the Ford rock rails/sliders are body mounted. You can go aftermarket frame mounted and you'll be able to use the jack along the entire length of the rail/slider. These will also extend further away from the body and offer a little more protection. Just an idea.
2Jeeps&PatriotX1
Denver, CO
Best lifting points and mounts for the hilift are on the garage wall or tucked away in storage? In 10yrs of wheeling everything from FL-CO-UT-AZ Ive never found the need to use or witness anyone in my group using a hilift on our jeeps or 4runners even with all the various trail repairs. But to each their own.
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
I agree, but for about $140, it’s not a bad tool to have with you just in case.
  • Like
Reactions: RG7
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '07 Camry
I recently used my Hi-Lift this past summer...to pull up broken fence posts...worked like a charm! :ROFLMAO:
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
Yeah, but they look badass on all those Jeep hoods at the mall.
DUSTYcazOREGON
Craig
A side question; with these Broncos being further off the ground, especially the Sasquatch....I would presume it will come with a taller/capable jack (not a jack typically found in cars and basic trucks). ?
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
Yes. Probably will be the same jack across all trims and packages.
rtaylor
R
ID
19Raptor, 22Bronco
Plus they are dangerous to use. Tippy and unreliable, with a long metal handle to break your jaw or leg. Responsible for many injuries since they were invented in 1905. They are mostly just for show now.
Ford Bronco Hi-lift jack points? 1608845463193
Clint
Clint
Clint
Columbus, OH
VW Jetta TDI
So is driving, what’s the point. Just like anything else, know the dangers and use good judgement. If you need it, you need it.
