Help with visual 17x9 +12 offset
Pete
PA
22 Bronco Big Bend
Hey all,
Im looking at a set of 17×9 (+12 offset) rims for my non-Sas Big Bend. I will have 285 70s mounted. I searched the wheel and tire thread looking for a visual, but couldnt find an image. If anyone has a pic of that wheel and tire combo on a non-Sasquatch, I would really appreciate it.
Thanks for any help
Raptor911
Raptor911
Broadlands, VA
May I ask what wheel you are looking at that is +12 offset?
ElDiabloBronco
Pete
PA
22 Bronco Big Bend
RockTrix RT110 17 inch Wheel Compatible with Ford 2019+ Ranger 17x9 6x5.5 Wheels (+12mm offset) 6x139.7 PCD, 93.1mm Bore, Black Wheels, Also Compatible with 2021+ Bronco Rims https://a.co/d/aBBbEJk
Ford Bronco Help with visual 17x9 +12 offset Screenshot_20221011-132403_Amazon Shopping
ElDiabloBronco
Pete
PA
22 Bronco Big Bend
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
If it helps, these are +18 offset (only about 1/4" less poke than +12). The tires are wider though they are 33x12.50
Ford Bronco Help with visual 17x9 +12 offset 20221002_174543
Ford Bronco Help with visual 17x9 +12 offset 20220820_112547
ElDiabloBronco
Pete
PA
22 Bronco Big Bend
If it helps, these are +18 offset (only about 1/4" less poke than +12). The tire are wider though they are 33x12.50
Thanks. With that set up, are you throwing a lot of stones or is it not bad? Just trying to protect the paint as much as I can.
1970AMCAMX
Robert
Titusville, FL
I think the throwing stones is caused by the tighter tread pattern of the Goodyear tires on the Sasquatch package, I have not heard or seen any being kicked up driving on gravel with the tires I have. I even have a set of mud flaps that I haven't gotten around to installing because I was concerned about it, now I'm considering not even putting them on.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
I don't have an image on hand, but can tell you that the 17x9 ET+12 is going to sit 2.5-inches further outwards compared to stock.
If you take a tape measure, and measure from the front lip of the factory wheel outward 2.5-inches, this will be the point where the front lip of the 17x9 ET+12 is going to sit.
ElDiabloBronco
Pete
PA
22 Bronco Big Bend
Thanks everyone for the help. I appreciate the quick responses
Dannebrog53
Kim
Vacaville,CA
1968 Bronco, 2022 Bronco Wildtrak, Porsche Macan S
Ford Bronco Help with visual 17x9 +12 offset image
Just got our Wildtrak home and agreed that the tread pattern of the Sasquatch Goodyears are gravel magnets. So far the only damage is 3 small dings in the driver’s side rear fender extension and that was from parking in a gravel lot at the vets. I’m going to fit some mud flaps on the Bronco to reduce possible damage to other vehicles on the road.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
Non-Sasquatch OBX with 315/70/R17 Wildpeaks that are 0.8” wider than you are planning on but these are Ford Sasquatch rims with +30 offset. You would have 0.3” more poke if my math is correct.
Ford Bronco Help with visual 17x9 +12 offset 988D3056-AE42-4A4F-87A3-A7D1A385A112
Ford Bronco Help with visual 17x9 +12 offset E6A1B177-0451-467B-80A0-E828947AE371
Ford Bronco Help with visual 17x9 +12 offset 3A4D8875-D69B-47F7-93BD-22FD679046D0
