17x9 wheels: 1mm vs -12mm offset
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
Here is my 37x12.5 17 on -12 offset
Ford Bronco 17x9 wheels: 1mm vs -12mm offset capable bumper
Yeti-X
Todd
Eau Claire WI
and for reference a 285 is not to narrow for a 9" rim
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
Here is my non-sas Black Diamond with 285/70/17 on 17x9 +30 offset.
Ford Bronco 17x9 wheels: 1mm vs -12mm offset B1
Ford Bronco 17x9 wheels: 1mm vs -12mm offset B2
Yeti-X
Todd
Eau Claire WI
ThisGuy611
ThisGuy611
E90 M3 6spd Sedan; EG Base Scheduled 3/27
This looks great, glad to see the 285/70r17 fits the 17x9 wheel. Would you go with the same size or get something wider if you did it again? If you have any pictures of the wheels/tires from an angle I'd love to see it.
I'm still between 33x12.5r17 and 285/70r17. Seems everyone has a different thought on what fits a 17x9 wheel lol.
kr_1315
Kevin
Houston, TX
I am perfectly pleased with my current setup. I didn't go wider because I don't like a lot of "poke". I also don't need mudflaps. I think the 9 inch wide rim pushes it out just far enough.
Ford Bronco 17x9 wheels: 1mm vs -12mm offset B3
Ford Bronco 17x9 wheels: 1mm vs -12mm offset B4
Ford Bronco 17x9 wheels: 1mm vs -12mm offset B5
fields_day
San Antonio
2022 4dr Badlands - 2023 2dr Black Diamond
Hey @Discount Tire .. Offtopic but since you're here, the guys at my local DT had to change my Bronco into a Jeep Wrangler so the system would allow them to order me 37's.. Is that still a thing?? 👀
ThisGuy611
ThisGuy611
This basically settles it for me, 285/70r17 it is. Additional benefit is I can get them in load range C instead of E which anything wider seems to be.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Fuel Zephyrs 17x9 with -12 offset here with fender deletes.
Ford Bronco 17x9 wheels: 1mm vs -12mm offset IMG_0603
Ford Bronco 17x9 wheels: 1mm vs -12mm offset 022023 2
BodhiMac
Mac
Coastal NC
This is -10 offset with 285/70/17 with standard flares
Ford Bronco 17x9 wheels: 1mm vs -12mm offset IMG_0394
Ford Bronco 17x9 wheels: 1mm vs -12mm offset IMG_0388
Discount Tire
Arizona, USA
discountti.re
All Things FORD
I'm nit sure why that would be a necessary thing to do in this case. I'd like to dig a little deeper into this. DM coming your way.
