Help with visual 17x9 +12 offset
blackbronco
CA
Mazda CX-5
Awesome. Thank you. This gives me an idea of how much poke it will have. Cant wait to see pics when you get yours set up!
My front wheels were slightly turned and I didn’t realize until after it was dark so those poke pics won’t help. I can take retake tomorrow if you need, but here are rear pics for now.
They are taken at slightly different angles (see the side window is visible in one, not the other). Hard to tell which exact angle is the most helpful.
Exact wheel/tire specs you are looking for.
Ford Bronco Help with visual 17x9 +12 offset 8694FF78-2121-442A-8576-37B9294624BC
Ford Bronco Help with visual 17x9 +12 offset E212DBB2-A0FB-4ADB-9353-C809750B24F9
ElDiabloBronco
Pete
PA
22 Bronco Big Bend
It took longer than I expected due to unforseen circumstances, but I finally got them mounted. Thank you all who assisted. I am very happy with them.
Ford Bronco Help with visual 17x9 +12 offset 20221108_164619
Ford Bronco Help with visual 17x9 +12 offset 20221108_164355
Discount Tire
Arizona, USA
discountti.re
All Things FORD
dbattle
Northern VA
2011 Toyota Prius
Non-Sasquatch OBX with 315/70/R17 Wildpeaks that are 0.8” wider than you are planning on but these are Ford Sasquatch rims with +30 offset. You would have 0.3” more poke if my math is correct.
Sorry if you've already answered this but do you have any lift on that or did you just take out the crash bars? I love the look. I'm thinking about Nitto recons at 315/70/r17. I need to find wheels that are around that +30 offset, it's been more difficult than I expected.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
1.25” leveling kit on the fronts and crash bars removed. I had the $160 leveling kit professionally installed for about $350 labor. I finally got my Sasquatch/MIC Bronco 6 days ago and am definitely going to do something different for the fenders as I like the poke better on my non-Sasquatch with the narrower fenders better. FWIW, the Wildpeaks look way better than the stock Goodyears which are gone after only 205 miles. The Eruption Green one has no leveling kit yet and I might leave it that way as the stock Sasquatch will work fine for my off-roading which is mostly MN hunting/camping trails and running it on snow packed frozen lakes.
Ford Bronco Help with visual 17x9 +12 offset B6812B58-B634-4314-8DBA-15BEBFA16438
Ford Bronco Help with visual 17x9 +12 offset 72AC4AEE-59D7-485F-BC8A-3497F3376192
dbattle
Northern VA
2011 Toyota Prius
Thanks, that was super helpful! Do you think it needed the leveling lift or was that just for the look? I'm guessing a 1.25" level doesn't mess with the geometry much if at all but it probably still needs a balance after the lift.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Any lift upsets the geometry. Impossible not to.
