Heated Seats in a Base?
GrayEagleRider
Jason
Maryland, US
Jeep Wrangler (YJ) Subaru legacy KTM 690 Enduro R
Anyone put aftermarket heated seats in a 6th Gen Bronco? I really think that’s the only option in a base model I’d miss. Would be cool if you could buy and use the factory climate control panel but not sure it would be that easy.
RagnarKon
Ford Bronco, Escape, Focus
Putting in the factory system would be... interesting. The Mid package (that has the heated seats) also includes the dual climate control system. So the panel that has the buttons for the heated seats is also the same panel that has the dual climate system, which obviously the Base Bronco does not have. Not sure if you could make it all work together honestly, and you'd probably be better off with going with an aftermarket solution.
I know Katzkin offers heated seats as part of their leather seat covers, not sure if they offer it standalone though.
DirtyGSer
Jay
Massachusetts
'22 2D 6MT BD, '24 Edge, '17 Abarth, '23 Norden, '25 DAX
Pretty sure someone commented on the idea that the auto climate control has more/different dampers and temp sensors so its not likely you could just connect it up and flip some things in forscan.
You can buy the factory heating elements from any Ford parts source BUT the two backs are on national backorder so you'd only have the seat base.
Would love to know if the climate panel would do anything if connected.
J
DirtyGSer
Jay
Massachusetts
I put Katzkin heated seats in my base. The controls are on the center console by the window controls.
Is that heat only? About how much did it run? They look GREAT!!!
Copperhorse73
Justin
Mooresville, NC
Yes heated only. I paid a little over 1500 for the 2 door version, heated only in front, I think the 4 door version is a bit more
Rdavis
Ronald
Hastings
i paid 2,500 for heated+leather front and back seats threw the dealer Ford
MNBigfoot
MN
Not sure if I've asked you yet, but I've asked a few. Do you know if the factory wiring harness for the heated seats were there (under the seats) to tap into? Or if not, where did they get the feed?
GrayEagleRider
GrayEagleRider
Jason
Maryland, US
That looks great! Very clean installation. Thanks.
GrayEagleRider
GrayEagleRider
Jason
Maryland, US
Thanks for the follow up. I totally forgot about the dual climate controls. I’m sure that would be too much hassle to attempt to make work.
Copperhorse73
Justin
Mooresville, NC
They fuse tapped the interior fuse panel
a.doba
Any idea if there are plugs under the seats that are pre-wired for the heated seats? Or Mid package would have a complete different harness ?
Gnomad
Harbor Springs
Land Rover LR3 HSE
One of the sales guys at the local dealer has a base and had heated seats installed. You can get the heated pads and install them yourself, or do what he did and pay a shop just for the heated part. He still has the cloth seats.
Mario3241
Mario
Las Vegas
Ford Focus
Do you know which fuses they used? installed mine and looking for a good accessory fuse for each seat. Found 2 but they’re right on top of each other and the add a fuses would be butting against each other.
HoosierDaddy
__ Eric
How much power do they pull?
Could one fuse feed both seats?
