Headlight trail damage repair
Tricky Mike
21 Bronco
Got around to fixing my rock scrape today. It's not perfect but it's acceptable now. I used the Mother's headlight restoration kit but had to start out with my own 220 grit, then 400, before moving to the most coarse pad in the kit, 800. I could probably get it perfect if I kept at it with the 220.
Ford Bronco Headlight trail damage repair PXL_20250530_234033009
Ford Bronco Headlight trail damage repair PXL_20250531_030050435
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Big difference!
Looks much better.
Wow that does look a lot better! Kinda surprised it got that clear with 800 and you didn’t have to go higher grit
Tricky Mike
Tricky Mike
21 Bronco
Oh no, I went all the way to 3000, which felt more like a cloth pad than sandpaper. 800 was just where the kit starts.
1bluedog
OH
340i, S2000
Impressed. Great job!
CitrusBronco
Everglades
Citrus county, FL
Everglades
Yep the sand paper method is the way to go for deep scratches or heavy yellowing on the older cars and makes them like new. I use meguires paint polish compound with the buffer for my final polish and on headlights that just need a refresh with no sanding.
javelina
Gregg
WAFB Arizona
Bronco, F-150, Jeep TJ
wow, great job!
