Grounding question
tater_70
Terry
64 Fairlane, 1973 Bronco, 75 F-100
I'm sure this has been covered somewhere on this forum but I'm in the middle of putting things together. Is it OK to use the factory ground that is located behind the drivers side rear panel (2 door) to ground a powered subwoofer. I only see one factory ground with a rather large cable. Just want to cover the bases.
Ford Bronco Grounding question 100_8998
Ford Bronco Grounding question 100_8999
Baja Bronco
2Sun AZ
Yep.
