Grille Light (like the Raptor)
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
their web site only shows them available for the Super Duty and the Ranger. I could be missing something...
Yep. Best I can tell it hasn’t come out yet, but iirc that’s the right conpany. The Bronco pictured is Havoc offroad’s 2021 Sema build.
Ares
Fox
Atlanta
Apparently you can change blinker to be amber all the time with forscan. I wonder if the rings could be done as well. Then one could have the raptor look for sure
the blinkers have an amber mode. do the rings have the same? I assumed they were DRLs only.
PrevCYBRTRKrez
Jacob
Decherd, TN
2023 4dr Badlands, 2020 Lincoln Aviator
I’m not sure. Need someone to play with it
Jer
Jeremy
Oklahoma
2021 Badlands,2017 F350, 2023 F150L, 1976 K20
You got a picture of yours how did you mount them?
I purchased this black plastic stock(way more than Needed). Cut small piece to fit behind the grill holes, cut out to fit the lights, bolted them in and dabbed glue on the black plastic to back of the grill. This way if they ever burn out or get damaged I can just unscrew them to replace. I trimmed the plastic with an exacto knife to match the hole so you can only see it the hole where the light is mounted.
https://www.amazon.com/gp/aw/d/B08R6LKS1L?psc=1&ref=ppx_pop_mob_b_asin_title
Ford Bronco Grille Light (like the Raptor) 1638662554986
Jer
Jeremy
Oklahoma
I forgot here is a pic with them on.
Ford Bronco Grille Light (like the Raptor) 1638663089775
Jose_911
Jose
Scottsdale, Az
Ford Explorer Sport
where did you hook them up to?
Jer
Jeremy
Oklahoma
To one of the 6 pre installed switches. I leave the switch on all the time, since power is disrupted when the ignition goes off they are only on when the Bronco is running. Makes them DRLs.
87gpe
Phillip
Charlotte
Tahoe, Supra
They look cool - but they'll get made fun of by the Raptor guys. I had a Raptor and it's comical seeing all the 4Runners and Tacomas running around with these lights slapped in there.
They're on the Raptor because of the width of the truck.
ELKS1
Ohio
2006 F150 1977 Bronco
Anymore info on this mod?
Jer
Jeremy
Oklahoma
Will they need an mailing address or just an email to write about their feelings? Just kidding, but who cares what some raptor owner thinks , it is just a light, albeit serves no purpose.
