Grille gap between fender
NeoS281
Bellevue, WA
2024 Bronco
Hi All,
I have a 2021 Badlands that has always had a small gap between the grille and fender. I recently purchased a new (aftermarket) Badlands grille hoping the gap would be eliminated however, its still present (maybe slightly larger).
Does anyone have any solutions to get rid of this gap? Thanks in advance
Ford Bronco Grille gap between fender IMG_4457
Rednek
Jimmy
Northern Alberta
hows the door gap?
NeoS281
NeoS281
Bellevue, WA
2024 Bronco
hows the door gap?
There's no door gaps. In fact, there's virtually no other issues with my rig. Just always noticed the small gap between the fender and grille
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Hi All,
I have a 2021 Badlands that has always had a small gap between the grille and fender. I recently purchased a new Badlands grille hoping the gap would be eliminated however, its still present (maybe slightly larger).
Did yo7 try pushing it in softly?
NeoS281
NeoS281
Bellevue, WA
2024 Bronco
Wonder if something on the grill is not seated all the way...
That was my thinking as well but I took the stock Badlands grille off yesterday and installed the new one and the gap appears slightly larger
I tried pushing it in softly and hard, lol. I guess the only thing to try is removing it again today and seeing if there's something preventing it from seating all the way
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
My grill has the same gap, I figured it was intentional because it's the same on both sides
mlsjr14
Chattanooga, TN
N/A
My Big Bend did not originally have any gap, but I just swapped to an aftermarket gloss black (Wildtrack/Badlands style) it now does. Oh well, at least it's even on both sides - but if anyone has a fix to adjust then I'd be glad to hear.
NeoS281
NeoS281
Bellevue, WA
2024 Bronco
My Big Bend did not originally have any gap, but after I swapped to an aftermarket gloss black (Wildtrack/Badlands style) it now does. I even exchanged grilles thinking the aftermarket grille was defective, but nope it's something to do with my truck. Oh well, at least it's even on both sides - but if anyone has a fix to adjust then I'd be glad to hear.
Would you be able to share a pic up close? I swapped to an aftermarket gloss back grill like yours and saw the gap widen substantially. I'm planning to drop my Badlands grill off to get painted gloss black if I can't find a solution with the current grille.
mlsjr14
Chattanooga, TN
N/A
Sure. Here is the aftermarket grille...
Ford Bronco Grille gap between fender 050F4D64-A999-46C5-96A9-147200DF232F
Ford Bronco Grille gap between fender 086C5595-7518-45C9-8A35-B930CD11DC99
Ford Bronco Grille gap between fender 14904DBD-8CF3-4C06-8D41-48A5326469B3
Ford Bronco Grille gap between fender 7D81C10F-52E3-4EA6-BCE8-6F4BF322794E
NeoS281
NeoS281
Bellevue, WA
2024 Bronco
Sure. This was the first aftermarket grille. Second is about the same…
Thanks for the pic. You might consider returning for a full refund. No way there should be that large of a gap especially if your original grille didn't have on to begin with. Just my 2cents
mlsjr14
Chattanooga, TN
N/A
BTW - It's much less noticeable in person, believe it or not.
NeoS281
NeoS281
Bellevue, WA
2024 Bronco
I did! Then I bought from a different vendor with same results. I imagine if I were to try even a factory grille it would be the same as yours. I think the difference is Big Bend vs. Badlands grills but not sure why others have not had similar issues...
I purchased the black Badlands/Wildtrak grille from Forbes Auto on ebay. I suspect the OEM grilles direct from Ford will fit close to perfect but they were on backorder when I checked the other day. I'm gonna try and return the ebay purchased grille and have my Badlands grille painted after seeing that yours is also having fitment issues.
I had a very small (but normal) gap on my original Badlands grille but nothing like what we are seeing with both of these aftermarket ones.
rtazz17
Connecticut
2022 Ford bronco big bend
I have same gap except I didnt think anything of it. Same gap bilaterally. Also changed grills with no change. Doesnt bother me. Not sure if it should. Looks fine. If it was different on either side it would bother me but its not.
rtazz17
Connecticut
Im guessing the picture looks worse then in person.
