Gremlin / Reported Issues Thread
Alberta
Base two door Bronco. 7 speed, I noticed first and second gear were getting a little notchy to shift into in the last week or so. Now when idling, I hear a grinding noise of sorts. I have less than 1300kms on it. Probably a bad throw-out bearing, yay
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I plan on drubbing this list tomorrow and update the thread.
J.C.
J.C.
2021 Bronco Big Bend
Test out your Sync 4 system. Pair with CarPlay (or Google Play) and test your screen. Then try to unpair your phone. This has caused a glitch to surface and the APIM fails completely. Once that happens it is a brick and they have to replace it.
eric0w
Los Angeles
Any news on the new replacement units?
mrjerry469
JERRY
BLACK DIAMOND
Windshield washer not squirting motor running nothing coming out
J.C.
J.C.
Last update was yesterday from Ford Engineering. They said they are working through the problems with progress being made but they are starting with the older ones first dating back to the beginning of October.
It sounds like there may be multiple issues. Not sounding good if they have been working on this since October and still don’t have those fixed.
MarkusBigBucks
Markus
Port Orchard Washington
2000 Ford Superduty 7.3 PSD, 2017 Ford Escape.
Add fuel fill outside cover not fitting flush to quarter panel. Looks like they used adhesive to connect the hinge to the outside cover and its coming loose.The gap you see causes the door to not sit flush with quarter panel.
Ford Bronco Gremlin / Reported Issues Thread FEF259F0-4476-40E1-88D1-0BE8D7DE98A3
  • Wow
Reactions: Cat
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
JJ Bronco
Justin
Columbus Ohio
Lexus RX
My digital dash has gone black, so no tach and the like.
Anyone else?
Thinking it's a quick fix but would love to be validated on that. 🤣
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Any update?
Anyone else?
Someone else just posted a blank dash a couple days ago.
JJ Bronco
Justin
Columbus Ohio
Lexus RX
Any update?
Okay I searched a couple of different ways to say and then nothing came up exactly I'll try blank dash.
Thx.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
JJ Bronco
Justin
Columbus Ohio
Lexus RX
