GOAT Fabrication Rock Sliders installed - review & photos
Bigcountry03
Addam
New Baltimore, MI
2021 bronco, 2019 Audi SQ5
Pulled the trigger on a set of 4 door GOAT Fabrication rock sliders. It was a no brainer as they are local and I could save shipping. Spoke with Adam on the phone half a dozen times before ordering. Customer service was top notch. Installation went well.
Best piece of advice I can give is leave all hardware loose until you get all hardware started by hand. After that tighten it up and you’re ready to rock!
I didn’t get the pinch seam covers at the time of this order. I will likely be calling Adam to get them ordered soon though. Love the way it looked on his rig.
Compare these to anything on the market. My bet is GOAT uses thicker material, better powdercoat process and is “made in America” (2 words according to prez). Grabbed a few pics at the local off-road park. Looking forward to our trip out west in the spring.
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos 99BF715F-2A6C-4685-BFDE-8928F2D7C2E3
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos F16D35A3-190C-4838-B07E-0CFEB74A79E0
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos 36A7A42E-9C7E-4520-AA43-E471AEE82BAA
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos 4F2B0CB1-26CB-4EBE-9370-E14BA2710B05
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Here are a couple more pics.
Those look good! The pinch weld cover would finish it off.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Looks good.
On the pinch welds: I just taped off, scuffed with 100 grit sandpaper, and flat black rattle canned my pinch welds. Holding up nicely.
I can also attest to the Goat Sliders working well first hand. I was at Trail Hero last week, in Sand Hollow Utah. I did a few 7 rated trails and landed, and slid, over rocks with the full weight of the Bronco on them. They held up perfect, other than some rash on the under side. Great Product
choppersean
Sean
Arvada, CO
'22 Badlands Sasquatch, 2-door, EG, 2.7, Auto
Did you guys install these yourselves? I have a set on order.....to be delivered Monday. They look pretty simple to install. Any troubles/issues? How much time did it take given they advertise as "bolt-on"??
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Righty tighty, lefty losey about covers it. Quick and easy by yourself project. Set them on a couple of Jack stands while you bolt them on if you don’t have help.
choppersean
Sean
Arvada, CO
That is what it looked like. I asked my son if I could bring them to his shop on Monday when they are due to arrive so that I can use his lift to make it easier. Told him it seemed we could do it together in less than an hour. He was skeptical and has seen some really shoddy shit on pickups that come to his shop. I think it will be easy with the right lift and tools......and his help.
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
Good tip on the jack stands. My Goat Fab sliders have shipped and I'll be installing solo.
Bigcountry03
Addam
New Baltimore, MI
Install realistically is about 15 minutes per side while on the ground with a second set of hands.
BroncoWTFAN
NJ
MachE FE & BL SAS 22
Is there any torque specs for the screws?
Bigcountry03
Addam
New Baltimore, MI
Installed the pinch seam covers on my new wildtrak. Waiting for my GOAT sliders to arrive (2nd set). Bolted right on with no issues. Fit under the rear inner fender perfectly too.
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos 27937D2B-EA9D-4BD6-AB41-E862A5804FD4
Ford Bronco GOAT Fabrication Rock Sliders installed - review & photos 0EA3CC1E-8491-4032-815F-43A9BF6B9359
BroncoWTFAN
NJ
Are you putting the goat sliders on this Bronco with the pinch seam covers? Wonder if it will fit given the tight tolerances on the sliders. Not much wiggle room.
Bigcountry03
Addam
New Baltimore, MI
Yes should fit no problem from what I have seen.
JessD05
Jessica
Boerne (say it burn-eee), Texas
GMC suv
Body or frame mount?
@Bigcountry03 @BroncoWTFAN
Do they really stick out far enough to use as a daily step also with the top plates added?
