Glue for MIC repair?
Arealhuman
James
Massachusetts
2021 bronco first edition
On the MIC rear, where the back window hydraulic is bolted to the MIC, it has separated and basically ripped out a chunk of the mic.
The that was screwed into the NYC. Still has the screws in it and the screws still have some of the MIC on it.
I've attached pics.
Basically what it looks like is that I could clamp it and glue it back on if I have an adhesive that will bind the MIC back together.
Wondering what glue or adhesive would be best for this application? I live in a cold area so it's something that needs to withstand temperatures either way. Also want something that will hold as there will be force exerted on it when the back window opens and closes.
I should add that the MIC is terrible and the second there is another option. I am going to take it.
I've already posted on here about a leak that is caused rust and I actually noticed another leak today
Ford Bronco Glue for MIC repair? PXL_20211122_212650666
Ford Bronco Glue for MIC repair? PXL_20211122_212656829
Bronco21fan
Angelo
NewJersey
I've attached pics.
Take it to the dealer have them take care of it see if you can get them to foot the bill on the soft top while you wait for mic replacement
Arealhuman
James
Massachusetts
Damn, I honestly wish I had the balls to do that, I'll consider it. I'll give them a call actually.
Unfortunately, I'm definitely the kind of guy that doesn't say anything if a restaurant brings me the wrong food and it's something I hate.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
By not calling Ford and bringing it in, it's potentially not logging the issue to resolve on a larger scale. It's so important we bring these in to Ford to log every issue like this, as well as get it fixed. As soon as you start messing with it, you risk Ford telling you to pound sand on a future issue because you tried to fix it.
Bronco21fan
Angelo
NewJersey
Stand up for yourself be nice about it but don’t let them treat you like a peace of shit either you bought an expensive new vehicle that has a major issue so take it in they will order you a new top but it will be a long wait
PWillette
Parrie
Maine
I don't see how this isn't under warranty...go to the dealer
Arealhuman
James
Massachusetts
It probably is, honestly. I just wanted to make the hardtop work since I like the look but it's clear they haven't figured it out yet.
PWillette
Parrie
Maine
Is this MIC 1.0 or 2.0?
ChrisCozart
Hickory Creek, TX
2023 Wildtrak - 2Door
Curious...why even attempt a home fix rather than taking it right back for a free Ford fix or replacement?
Lifeliberty
Moonbeam👀
Columbus, OH
This is the second time I've seen this on b6g, you need to call your dealer
Looks like exactly the same separation
If you glue it, i bet it will just separate again
Lifeliberty
Moonbeam👀
Columbus, OH
It's probably the reason for hard top delays, they probably don't want to place all of them, i wouldn't
Arealhuman
James
Massachusetts
Just saw on fords instagram that they have hard tops for all broncos now. Wonder if this is a 3.0 or if it's just 2.0's
Lifeliberty
Moonbeam👀
Columbus, OH
