Gear indicator for auto tranny?
SKL1
S
AZ
2022 Bronco
Is there a way to have the gear indicator on all the time in the display? I see it when in manual mode but would like to have it show which gear all the time.
Can the dealer code that?
1975U15
2019 F-350 SD, 1975 Bronco
If you are you asking if you can see what gear within the 10-speed you’re in - unfortunately the answer is no. Unlike F Series and other Ford models, no gear point available.
Makes me wonder why they didn’t just plant F-Series interface into Bronco. Commonality with experience and parts. Guessing a $$ thing.
dgorsett
colorado
F250, Mustang, Explorer
If you hit the + or_ in drive you will briefly see the gear you're in. You can also manually downshift in drive to hold back on a downgrade, but it will revert to automatic if you give it throttle. I wish it was like an f series also.
