Function of Mechanical Key?
RHeinz
Ric
Houston, TX
Badlands, Lux, Remote Start
My key fob has a mechanical key that pulls out of it. Read through the owners manual and perhaps I missed the part about it.
What is its function?
jtt411
Jason
VT
2011 Outback
Locks the glove box and arm rest console. Also goes in the child lock mechanism on back doors.
RagnarKon
Ford Bronco, Escape, Focus
Unlock the doors in case of a dead battery on either the vehicle or the key fob itself, also does the child locks and the center console/glove box lock.
Also… should your key fob battery die, there is a spot near the bottom of the center console where you can place your key fob to start the vehicle even if the battery on the key fob itself is dead.
RHeinz
RHeinz
Ric
Houston, TX
There are no mechanical door locks. How does one unlock the Bronce with an absolutely dead battery?
RHeinz
RHeinz
Ric
Houston, TX
OK…Just looked. There is a mechanical lock on the drivers door. Missed it.
Thanks.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
OK, where is this "spot"? :)
Are we talking about where the shifter is? or actually on the center console? I looked at my center console (manual) and there is no place to put a key fob other than the tray area.
RagnarKon
Inside of the center console storage compartment at the very bottom. On most Ford vehicles they have a little picture of a key fob to show you where to put it—not sure if that is true for the Bronco.
Personally... I would take the battery out of your key fob and test it. My wife had an issue with her key fob on her Escape, and I told her about that trick and it didn't work. After about 5 hours of troubleshooting in a parking lot... it turns out the connector for the key fob sensor (I assume it's just an NFC reader) in the center console had wiggled loose—probably wasn't connected all the way at the factory. So yeah, test it... one of those things you only will use if you really need it, and it would suck to have it not work when you need it.
Headsong
Inside the console, pull out the fabric bottom... Voila.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
They are called valet keys. Means you can lock your console and glove box and the person you give your key can only operate the vehicle. They can’t touch your stuff.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Ford Bronco Function of Mechanical Key? Unknown
I don't like it when people touch my stuff !!
helifino16
Ron
Mount Sinai, NY (Long Island)
Picture from Owners Manual:
Ford Bronco Function of Mechanical Key? 1668090591391
