Front Grill Dampers
LSOR
Phil
Westchester, PA
2022 Ford Maverick
By chance does anyone know what would happen if you removed the dampers behind the front grill? Trying to mount a winch in as close as possible. Removing those would help.
flip
Phil
IN
www.ruxerparts.com
Fords
Check engine light probably.
BlueBronco
DFW
@LSOR have a look at this post to see what is all back there. Now that I have dug into it I think I may cut the center section out of the bumper so I can lower and tuck a winch in there as much as possible.
If unplugging the servo throws a code you can always just strip it out of the house and tuck it behind the skid plate so it is still plugged in but not doing anything.
Jug
DFW
2021 F150
Some of the old ecoboost F150's had a condensation issue. I think the shutters helped with it. But I think they have figured out how to design them better now, so it shouldn't be an issue.
AZ_Liberty
2007 Expedition
What exactly are these stupid things for anyway?
As someone who lives on the surface of the sun, I want as much air flowing across the radiator as possible.
Bronc-O
Phoenix
2021 Lincoln Aviator
They're called active grill shutters. They close at higher speeds to reduce drag and increase gas mileage.
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
Improves aerodynamics as has already been said but also helps the engine warm up faster. Both are good for your wallet.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I would imagine (or at least hope) that they would also function as a winter front to keep engine temperatures up in the extreme cold.
