Front FDU replacement (resolved)
Baja_bronco
Andrew
Hemet ca
2022 bronco wildtrak, 1996 bronco
After replacing my front FDU dash looks like a Christmas tree and locker won’t engage. When swapping out to a new one does it need to married to the vehicle?
Ford Bronco Front FDU replacement (resolved) IMG_6854
Ford Bronco Front FDU replacement (resolved) IMG_6853
Ford Bronco Front FDU replacement (resolved) IMG_6852
Ford Bronco Front FDU replacement (resolved) IMG_6851
No. There's no actual electronic connection to the FDU (other than the locker or FAD, and W/T's don't have a FAD). It's a happily dumb piece of hardware.
Odds are you jacked up a wheel speed sensor - I'd go check those out.
Also - check DTC codes - it will probably point you in exactly the right direction.
BigMeatsBronco
Allan
2021 FE 2 door
Did you also change the ratios?
Baja_bronco
Baja_bronco
Andrew
Hemet ca
Thank you for the help.
Did you recheck all of your connections?
yes thoroughly. Gonna start with the wheel sensor like Brian suggested.
It’s just a stock replacement from Ford. I ordered both front wheel speed sensors. We’ll see if that helps.
Baja_bronco
Baja_bronco
Andrew
Hemet ca
Valhalla
Valhalla
Chattanooga Tn
Update!!! Driver side speed sensor was bad. Changed both just because and everything cleared. 👌🏻💯
Can you change the title to add resolved?
