Front driver side axle (left side) feels loose
P@pper B@ggins
Arnaldo
East Hartford, Hartford, Connecticut, USA
2021 Bronco/ 1998 Honda C-RV
I Just installed my zone spacer, perch lift w/ UCA's on my 2021, non sasquatch, Black Diamond. After doing the work everything was fine and "tight", I took it for a test drive and nothing seemed out of place. the next day I brought it for an alignment and now my axle is tight left to right but if I wrap my hand around it and jerk it, I mean, push and pull front to back, I can make it rattle like a maraca 😂 (for lack of a better term). Took it to ford and they stated, "there seems to be nothing wrong with the axle and there doesn't seem to be any safety concerns". Needless to say, that isn't making me feel more comfortable, seeing as the passengers side does not behave in the same manner. I am afraid that it is putting more stress on that axle side.
Does anyone have any insight? Also, where can I buy the left side axle only? I think my trim/non sasquatch has the 190 axles
PWillette
Parrie
Maine
Rattling like a maraca is not a good sign. You say perch collars were installed which requires the coil over to be removed from the truck...was the axle removed from the knuckle during this process? If not, the CV probably got over extended and came un-done.
flip
Phil
IN
www.ruxerparts.com
Fords
Were the axles removed from the hubs when you did the work? Need last 8 of VIN to verify the correct axle part number.
P@pper B@ggins
P@pper B@ggins
Arnaldo
Yeah
Yeah I removed the axle from knuckle seems that the joint nearest the engine seems to be the issue.
P@pper B@ggins
P@pper B@ggins
Arnaldo
Left MB3Z-3A427-B
Right MB3Z-3A428-B
Said F it and aired on the side of caution. Hopefully I didn’t damage anything or don’t damage anything until then.
I am really surprise for gave me the everything is fine speech knowing full
it’s not.
akturbo
Seattle Eastside
Post a video!
P@pper B@ggins
P@pper B@ggins
Arnaldo
Post a video!
not a bad a idea to give a visual, you’re right! I’ll proba
Post a video!
[/QUOTE
not a bad idea, I’ll probably have it uploaded within the hour. Started yesterday but got lazy when I realized I didn’t hit the record button.
P@pper B@ggins
P@pper B@ggins
Arnaldo
Post a video!
Also and if I am recalling correctly, The boot didn’t look like that until after I took it to get aligned. The grease on it isn’t from the boot btw that’s from the upper control arm. I over filled the UCA And grease landed on the axle.
akturbo
Seattle Eastside
That’s no good! Not seated or wrong axle? @Snacktime and @BigMeatsBronco ??
P@pper B@ggins
P@pper B@ggins
Arnaldo
It’s the axle that came with the vehicle (Dana m190) . I lifted the vehicle, put everything back together, everything was working fine until I brought for alignment. The morning after I noticed that something off, I went to the alignment shop and they stated everything was fine.
I then took it to ford and they stated everything was ok with the axle. Needless to say, I don’t believe either of these places, the new axle will get here today and once replaced I will have some peace of mind.
I will see if I can make rattle after still replace and post another video so that this thread can have some closure 😂🤣.
P@pper B@ggins
P@pper B@ggins
Arnaldo
Perfectly normal, just held in by the spider gear with a ring clip.
Axel was shot btw, here is closure on this thread. For advised me it was perfectly normal but it wasn’t. I f fixed it and everything is working exactly as it should.
