Front camera cleaner nozzle is leaking nonstop
HurricanE
‘18 F150
Good evening!
Picked up my badlands 2 days ago and today noticed my front camera cleaner nozzle is leaking nonstop… I’m almost out of washer fluid lol
Any ideas how to disconnect it?
Thanks in advance.
HurricanE
‘18 F150
T
Take it to the dealership and get it fixed. Should be covered under the warranty.
That’s the plan, just trying to get it to stop in the interim.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
There’s no leak in the front of my base
da_jokker
Jeep Wrangler JKUR
I don't have my bronco So I can't confirm, but at the top of my head I think of two things.
1 possibly pull the fuse that handles the windshield cleaners, of course that depends on if it's the pump doing it and what else is on that circuit.
2 The rubber hose that leads to it.. If you can find it pinch it, or put a fold in it with a zip tie. Basically do like you would do for a garden hose.
Harbor freight has some clamps that I've used many times. It might be a little overkill, but it would also work.
https://www.harborfreight.com/4-piece-fluid-line-clamp-set-65116.html
HurricanE
‘18 F150
I actually fixed it this morning. Turned on the front camera d reran the windshield wipers. Seems like it just had a clog.
Bschurr
NY
FYI - there is a connection to the water line under the radiator shroud that is held down by 9 plastic pop rivets. This needs to be disconnected (along with the camera wiring) when you remove the grille. I was going to suggest to check there.
Glad you got it solved!
da_jokker
Jeep Wrangler JKUR
Are you sure you just didn't run out of windshield wiper fluid? ;)
A1A
'08 FJ Cruiser
.....S.T.D.'s man....
