Front Bumper Nut Plate
suineg
Gabe
2024 Outer Banks - Sasquatch
I’m trying to get a DV8 bumper on while using the original nut plate and nothing lines up. I mean I can get some of them but not all. So I need to switch to nuts instead.
What would people use that matches the threads on the nut plate?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I can’t see why the oem nut plate wouldn’t work as it lines up with the frame horns. If there is an issue its either your new bumper or alignment of the bumper.
suineg
suineg
Gabe
Yeah it’s 100% the alignment of something but since I can’t muscle it in with 3 men today the rigid plate is getting scrapped for nuts.
I’ve read a few people having this issue in general.
The bolts go through just fine and I just can’t get them to all thread to the plate. Also the design of this bumper makes one bolt very hard to get to so if I can tighten from the rear it will be infinitely easier which means more likely to be torqued correctly.
GI_Jo_Nathan
Jonathan
Best thing I can think is take a bolt to the hardware store and get some grade 8 lock nuts and good washers.
Copperhorse73
Justin
Mooresville, NC
I did a dv8 bumper install a few years ago and it still haunts my dreams. That last bolt is friggin impossible
suineg
suineg
Gabe
Yeah talk about the absolute worst. If I had realized how difficult some of their decisions made things I might have chosen another look.
Ranbronc
Pa
Early Bronco
I found the nuts are bent on the plate , straighten them and run a tap thru them helps.
I still have one plate to reinstall cause I was in a rush last install.
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
M12x1.75 IIRC
Tricky Mike
21 Bronco
M12x1.75 IIRC
Sounds right. Undoubtedly M12, and the pitch is fairly coarse.
Better off ditching the cheeseball nut plates anyway, they'll rip through if you put some decent force on the bumper.
suineg
suineg
Gabe
M12x1.75 IIRC
Thanks I did what @Tricky Mike suggested and got rid of them. I need to back them out and apply red thread locker before I’m satisfied but it’s on there now.
Ford Bronco Front Bumper Nut Plate IMG_1036
I’m also going to try and engineer, then 3D print, some inserts for the hand holes on top.
AdamF@IAG
Adam
Maryland
iagoffroad.com
That shouldn't be too difficult, looks good!
