Front Axle Caps
Bruno
Bruno
Sierras
Im looking for a way to cover my front axles.
I know they look rusty, i will wire brush and lube them
I will paint the surrounding hub face with Por15 after cleaning them up
I dont think the factory hubcaps provide any real protection from surface rust
I also think the factory hubcaps dont look good.
Any advice is appreciated
https://www.ford.com/product/bronco-front-axle-hub-nut-pair-p2998490674
Ford Bronco Front Axle Caps 1763079383080-vy
Ford Bronco Front Axle Caps 1763079911661-a
Ford Bronco Front Axle Caps IMG_5102000
Ford Bronco Front Axle Caps IMG_5103000
Rivers90
Ben
Southern California
2 Door Base Sasquatch
Bruno
Bruno
Bruno
Sierras
wire brush the rust off, rub a little bit of axle grease on the threads, and put your hubcap back on and don’t look at it again until you rotate the tires next time
SeptuagenarianSasquatch
Randall
A hub cap?
https://ford.oempartsonline.com/oem-parts/ford-cover-wheel-m2dz1130b
The rust is normal it is a steel part.
You could paint them but if paint got on any of the parts around them you would have problems.
I would worry about your lugnuts first, they are not looking so good.
And don't get just any M12 x 1.5 lug nuts from the auto parts store. I'm not conversant with the terminology, but the edge of the lugnut is beveled in a special way to meet the matching edge on the wheel. You could crank generic lugnuts down good and tight, but they wouldn't fit right. Probably best to get them from a dealer.
Bruno
Bruno
Bruno
Sierras
my lugs are factory, my wheels are factory & my lugs have zero issues
this post is about a cap for my axles
Bruno
Bruno
Bruno
Sierras
thanks - this post is about finding an alternative to the plastic hubcaps - something i can screw on or push on to the actual threaded axle part just for added protection
Valhalla
Valhalla
Chattanooga Tn
Not sure but measure it and check out some trailer hub dust covers.
Valhalla
Valhalla
Chattanooga Tn
As for the axle, clean it, tape it, shoot it with a cheap rust resistant paint.
