- Robert
- Mar 26, 2023
- 6
- 50
- 85
- Tallahassee
- 2023 Bronco Big Bend, 1942 Ford GPW (jeep)
- Big Bend
I'm new to Forscan. My Bronco is a 23 Big Bend that came with the 6 speaker delete option. Yesterday, I installed a Ford Fusion amp and a kicker 6.5 speaker. Very easy overall.
Downloaded, activated Forscan, using the recommended dongle. Connected to the Bronco. Copied/saved original setup. Went to the ACM and edit line 727-01-01. In the SECOND column change 14F1 to 16F1, THIRD column change 0098 to 009A. Clicked Write. Pressed OFF then ON, then OK. Thought I was done. Went to disconnect and nothing happened. After waiting several minutes, I turned the Bronco OFF and then disconnected the dongle. Tried to reconnect (after plugging the dongle back in) with the Bronco ON and Forscan says it cannot connect. Not sure what I did wrong.
