FordPass app vehicle location issue
rugedraw
Javier
Miami, FL
2021 Ford F150 701a 3.5tt 4x4
Does anyone that is experiencing this issue have FORScan? Is so, plug your truck in and go to line 754-10-01 in the TCU. If you anything on that line other than "5553 14" then that is the problem.
If your connectivity is working and it is just the location that is off, then this is not the issue. Example: If Fordpass works and connected nav works, etc, then you are not affected by this.
Ford Bronco FordPass app vehicle location issue Picture2
Or post or message me the VIN and I can take a look to see if I can figure out the problem.
Same here -- all the rest of my Fordpass stuff works fine, just not the location. Happened shortly after 6.1 Update.
Baerkeeper
Los Angeles
2023 2dr Basequatch | 2020 Miata RF
Anyone try disconnecting the battery to see if it gets it working?
Phil James
Phil
Denver
S2000
Yesterday, 5/11, I had a new update and location now shows my actual location. It's slow sometimes. I hope that has happened for everybody.
... though lock/unlock still only works sometimes. :- )
