Ford OEM Hoop Steps
vzqhsg
MI
F-150, Badlands
  • Thread starter
  • Banned
  • #1
I ordered the hoop steps on my Badlands. I don't do the extreme off road stuff so I'm not worried about the fact that the hoop steps won't carry the weight of the truck. The HS's are very nice, glad I got them. I got to thinking if the steps would fit the actual OEM Rock Rail. Haven't been able to find anything on this. Going to ask the dealer tomorrow. Was wondering if anyone has tried just the Ford HS on the Ford RR. I know you can but 3rd party steps to fit the RR, but the steps were more expensive then the HS option.
Thanks
FreddieLee
Freddie
Bronco & Tesla M3
The HS cannot be mounted on the RR.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
The iAG steps attach to the Badlands rockrail, and are removable. All you need is a hex wrench and an adjustable crescent wrench. I have the full-length, and endorse them heartily. They also come as per-door steps, get one or two pairs depending upon your rig.
Ford Bronco Ford OEM Hoop Steps 1692589389710
$280 2 door
$550 4 Door
Ask for veterans/1st responders pricing if you qualify.
ChrisB351
Shreveport, LA
Thry are designed for RR. I ordered from factory. The picture is from delivery day
To my understanding if you ordered hoop steps you got a whole different rail. Its not the standard rock rail.
ChrisB351
Shreveport, LA
Thats correct, I was hoping he bought the hoops seperate and figured out how to mount to the standard Rock Rails...
Ive done some research cause Im planning to lift my black diamond soon and will need them. Looks like IAG is gonna be the winner.
WhiskeyCity
Shannon
Bardstown, KY
2023 Bronco Badlands Sasquatch 2.3L, 7spd
I ordered the steps from the factory with the Bronco. If you bought them after the fact, it looks like you'd have to drill a couple of holes. I haven't taken them off but they are removable.
If I had to do it all over again, I would probably do the IAG steps. They are higher clearance than the OEM steps. I do love my OEM steps though. If I do some serious wheeling, I'll just pop 'em off.
Ford Bronco Ford OEM Hoop Steps Side Step 1
Ford Bronco Ford OEM Hoop Steps Side Step 2
Broncolands
Ricardo
Massachusetts
GLE350
Well now I feel dumb. Pay extra for less features. Not sure they had that fine print when i order. If i knew it would lose the standard rock rails i would probaby never order it. I wil probably never use the rockrails either.... so be it.
B_Wagon136
SoCal
Black Diamond Bronco
Good sir, can you confirm that you drilled holes into the factory rock rail to mount these OEM hoop steps yourself after the fact?
To my knowledge, the Black Diamond and Badlands come with the same factory rock rail, so if this worked for you then it should work for me. But I've heard whispers that the oem hoop step is not compatible with the oem rock rail on these trims (if one ordered oem hoops through build&price, it comes on a different accessory rail thats different from the standard rock rail).
WhiskeyCity
Shannon
Bardstown, KY
I ordered the hoop steps from the factory (build & price) so they arrived already installed on my truck at delivery. They did come with a wrench to remove the hoop steps and plastic caps to cover the holes if I decide to take the steps off.
I hope this helps, cheers.
