Ford Cargo Drawer installed - notes and feedback
Morganstein
2021 Ford Bronco Badlands
Installed this morning and wanted to share a few things before anyone else has the same issues.
#1. The drawer itself seems great and install was not bad, even by myself.
#2. It does not level the floor with the folded seats, but it's no worse than before. It's just higher in the back than the front now.
#3. The most important: The nuts they have attached to reinstall the cargo hooks on the top of the drawer will spin. I quit when 3 out of the 4 I tried spun. Now I have to take the whole thing back out because the 2 hooks I installed are loose. I'm just going to take a cutoff wheel to them and reinstall them with washers & nuts underneath.
Morganstein
Morganstein
FIXED. Hopefully this will save someone the need of having to pull whole thing out like I did. Under the top, there are 8 round "nuts". If you grab these with a pair of vice grips, you can tighten the bolts down.
Ford Bronco Ford Cargo Drawer installed - notes and feedback 20211126_225628
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
Can we see it with the back seats down?
I would like to see the height difference
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Can you please show a pic of the interior storage?
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
interesting you powered through the nuts, i got stuck on one, backed off, and left the tie downs off, i'll give it another go i guess. i kind of assumed i was cross threading or the screw and nut did not match
Morganstein
Morganstein
I felt them same way. I pulled the whole thing out and had everything ready to drill out the nuts when I figured this out.
Tortuga353
Laguna Beach, FL
Ford Bronco Ford Cargo Drawer installed - notes and feedback AB579852-1EF0-4E1E-9679-1629DA620A9E
