Fog lights without aux switches
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
2 door, BB Sasquatch. Mod bumper, no fog light switch inside, so I’m assuming the wiring isn’t present. How much of a pain in the ass is it to run some street legal fogs? Any help, direction, or links are appreciated.
Fog Kits:
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
We make pigtails so you can put 1 pair of lights (usually SAE Fogs) on the factory fog switch. Yuo DO need to buy the factory fog switch panel from Ford AND you need to use FORSCAN to program the circuit on. But there are pigtails behind the tow hooks (remove plastic trim, you'll see them on the bottom under the tow hook). One on each side.
Then use our pigtails
Baja Designs: https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
Diode Dynamics without Back-Lighting (SS3): https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
Diode Dynamics WITH Back-Lighting (SSC2 and SS3 with backlight): https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
If you don't have the wiring or want to mess with the switch, what I have done in the past is to wire them up myself using a relay. Power comes from the battery and the signal from the parking light. The fog will always be on with the parking light, but I always have the fogs on like that anyway. As a bonus, I have also installed driving lights using the high beam as a signal ;)
Riverjeep
Va.
Wildtrak, F-150
I made a video of my fog light install. The factory wiring if yours exists is @ 24 seconds in.
If you don’t mind can you share the light switch part number? TIA
RCArea51
RCArea51
CRR
2 door BB Sasquatch
Are these fog lights road legal?
Fog Kits:
etmccaus86
Evan
Motor City
'22 BaseSquatch
The base '23 4 door bronco without fogs or aux switches DOES NOT have the wiring for fog lights. I just wasted a good bit of time looking for it and there is definitely nothing under there.
Why would aux switches have anything to do with those connectors being there?
Ducati1098
You’re right, It doesn’t.
I think the only thing that makes a difference is whether or not it has the front parking aid sensors from factory, because they’re on the same harness.
NO factory fog lights and NO factory front parking aid= No factory fog light wiring.
NO factory fog lights, but there IS factory front parking aid= factory fog light wiring is there.
Riverjeep
Va.
Wildtrak, F-150
Funny you say that as I just rode through the local Ford dealer lot and noticed that the base Broncos even with 2.7 auto and sasquatch do not have fog lights. So, if you op for the steel bumper there is no fog light delete hence no fog light wires. The aux switches don't affect it at all, they are a separate deal.
Riverjeep
Va.
Wildtrak, F-150
Makes sense, I was just thinking the wires are there if the Bronco trim would normally have fog lights but when you op for the steel bumper you get a fog light delete but wires remain.
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Is that the switch for a 23?
Most likely since I don’t think they changed the head light switches between 21 22 or 23. There might be some part number that supersedes that one I posted though.
RCArea51
RCArea51
CRR
2 door BB Sasquatch
I have a sheet from the dealer with different switches. The numbers are similar except for the DA at the end. So that’s where I’m drawing a blank
