Fog lights on standard bumper
zookeeper
Sharon
Knoxville, TN
2024 BB 2dr
Hi All,
I've seen previous posts on this, but one, not exactly what I'm looking for and two, older posts, so hoping there is better news for me! I've done quite a bit to my BB basic, and just about out of ideas, except for changing the bumpers out. So my next thing I want to do is change out the fog lights for something directional or brighter or just plain cooler lol. Any ideas? 2 dr, I've done all the work myself (with some help on a couple things from my neighbor kid), so pretty handy. Don't want to spend an arm and a leg, but maybe an arm lol.
Ford Bronco Fog lights on standard bumper 20250317_194444
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Go with either the Baja Designs or Diode Dynamics Fog Kits:
Baja Designs
https://www.4x4truckleds.com/baja-d...light-kit-ford-2019-22-ranger-2021-22-bronco/
Diode Dynamics
https://www.4x4truckleds.com/diode-...plastic-capable-bumper-2021-2023-ford-ranger/
We've also got some Diode Dynamics fog kits on sale if you don't care about the back-lighting option
https://www.4x4truckleds.com/diode-...-2019-2023-ford-ranger-2021-2023-ford-bronco/
So you can get the SS3 Pro Kit for $284.96 (normally $379.95) which is a steal!
Headsong
I think you'll find it rather easy and inexpensive....I went with yellow @Diode Dynamics very easy plug and play and spend what your budget allows. They are amazing. Much better than the friggin' headlights.
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
If you're looking for an OEM-style upgrade with superior performance, I'd highly recommend our Elite Series Fog Lamps. These are designed, engineered, and assembled right here in the USA, offering a perfect blend of style, function, and durability.
✅ High-performance OEM-grade replacement for the Ford Bronco
✅ Custom-engineered optics for an extremely wide, intense beam pattern
✅ Distinctive amber backlight for a unique, modern look
✅ SAE F3-compliant, road-legal fog light – no worries about compliance
✅ Plug-and-play installation – no modifications needed
With these, you're getting an upgrade that not only enhances visibility but also adds a sleek, factory-style fit. Let me know if you have any questions!
https://www.diodedynamics.com/elite...qEE_5pmSWq0A3F-SBG5r_jJ9xnwgpIO8PlA5Dbobmb8WI
Ford Bronco Fog lights on standard bumper 1743080433578-7d
Ford Bronco Fog lights on standard bumper 2021_Ford_Bronco_Elite_Series_Fog_Lamp_Close_Up_Collage
Ford Bronco Fog lights on standard bumper 2021_Ford_Bronco_Elite_Series_Fog_Lamp_Output_Collag
Ford Bronco Fog lights on standard bumper 1743080450612-jn
Ford Bronco Fog lights on standard bumper 1743080462491-b4
NatureMan
United States
I would go with diode dynamics SS3 max in amber/yellow if i was replacing a single pair of fog lights.
I ended up buying the dual DD kit from 4x4, and only regret was buying the pro fogs in yellow instead of max in yellow. I much prefer the cleaner cutoff of sport and max vs pro for fogs.
I still may order max and use the pros on something else.
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
If you're more into off-road styling but still want top-tier performance and road-legal output, I'd recommend our SS3 Fog Light Kit. It’s packed with performance and designed as a direct replacement for the Ford Bronco’s fog lamps—offering a perfect blend of functionality and aggressive styling.
Ford Bronco Fog lights on standard bumper 1743080664303-36
🔹 Direct replacement for Ford Bronco fog lamps
🔹 SAE-compliant, road-legal output – no worries about street use
🔹 Custom bracket with bezel for a factory-style, clean appearance
🔹 Bolt-on installation with plug-and-play wire adapters – no cutting required
🔹 Advanced TIR optics for maximum efficiency and focused light output
🔹 Durable powder-coated aluminum die-cast construction for longevity
🔹 Designed, engineered, and assembled in the USA
If you’re looking for an upgrade that enhances both style and performance, this is the one to go for! Let me know if you have any questions.
https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2021-2023-ford-bronco-w-standard-bumper.html
Ford Bronco Fog lights on standard bumper 1743080785004-g4
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
This is true, the SS3 Pro does have a taller beam pattern that some users do not prefer. The SS3 Sport is a fantastic starting point with a tighter beam pattern or you can go all out with the SS3 Max, which provides the highest intensity and widest consistent output on the market across the entire band of light.
Ford Bronco Fog lights on standard bumper SS3_Elite_Mega_Collag
Here is a great comparison video for anyone wanting to learn more:
zookeeper
zookeeper
Sharon
Knoxville, TN
2024 BB 2dr
I like these a lot! I've got aftermarket headlights and trail site lights piggy backed into my headlight harness, will that make a difference for install?
Smocaine
DFW, TX
Cervelo Caledonia
Those drop-in fogs come with the same connector as your factory foglamps for the main beam plus a tap for the backlight. Assuming your wiring is sufficient gauge, this tap could probably be worked into your existing headlight piggyback setup to run the backlight. I think Diode Dynamics backlights generally draw very low current.
zookeeper
zookeeper
Sharon
Knoxville, TN
2024 BB 2dr
Thank you. Now I've got to decide if I go for these or change my bumper lol. I really like these though.
zookeeper
zookeeper
Sharon
Knoxville, TN
2024 BB 2dr
Well, I ended up with the Diode Dynamic Elite yellow. Absolutely love them! So easy to install!! And if I upgrade my bumper to the capable, they'll still work!!
Ford Bronco Fog lights on standard bumper 20250408_200054
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
That 3k yellow looks fantastic! Nice choice, and I'm happy to hear about the easy plug-and-play installation as intended.
Arrmjr
Rick
SW Washington
Honda Accord and Civic
Will these work in the Capable bumber?
Arrmjr
Rick
SW Washington
Will these work in the Capable bumper?
